Paint Will Not Lay Down (Brush Marks) - Painting - DIY Chatroom Home Improvement Forum
Like Tree25Likes
Old 07-30-2019, 12:57 PM   #1
Rewards Points: 150
Ok I'm using a pretty good quality paint (Mccormick Paints Total Advantage Semi-Gloss
I'm not over brushing and have added latex additive (Floetrol) but it still won't lay down.
Help
Kemper100 is offline   Reply With Quote
Old 07-30-2019, 01:00 PM   #2
retired painter
Rewards Points: 1,298
Re: Paint Will Not Lay Down (Brush Marks)
What is the air and substrate temperature? Is this interior or exterior?
Sometimes it's beneficial to thin the paint and apply 2 coats.
mark sr is offline   Reply With Quote
Old 07-30-2019, 03:47 PM   #3
Rewards Points: 2,744
I've never heard of that paint. I stopped using floetrol a long time ago. I use glycol based extenders now. They work much better, but they do thin the paint, and makes sags happen easier. You also need a very good soft brush. I like Coronas.
woodco is offline   Reply With Quote
Old 07-30-2019, 07:09 PM   #4
Rewards Points: 150
Old 07-30-2019, 07:15 PM   #5
Rewards Points: 150
Originally Posted by Kemper100 View Post
Sorry my mistake it was McCormick Paints Premium White Semi Gloss
The Total Advantage was the Eggshell wall finish
Old 07-30-2019, 07:38 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,014
Funny, just this weekend at my daughter's I'm biotching about some really crappy Behr "premium" satin. I have used Behr on other jobs and do not know if they have drastically changed the formula.
One, it would not lay down and brushed on like crap..... Purdy's best latex soft brush. You could not keep up with a wet edge doing a raised panel door.
I went and got XIM extender, it helped.
I ended up doing the door in sections considering it's fast skimming property. (This was done early in the morning, relatively cool 60 degrees, moist ocean mist in Half Moon Bay. First the panels, then the verticals and horizontals.
Two coats/relatively heavy, over a preprimed interior doors, and still did not get great coverage.
I do not remember Behr being THIS CRAPPY...at $42/Gal.)
MTN REMODEL LLC is offline   Reply With Quote
Old 07-30-2019, 08:04 PM   #7
Yeah, I googled it. I've never heard of it, so I cant say whether its good or not. They dont brag about it being good on trim though, so Im guessing its just a good wall paint. Post a pic of your brushwork.
Old 07-30-2019, 08:05 PM   #8
I dont remember Behr ever NOT being crappy.
Old 07-31-2019, 04:19 AM   #9
retired painter
I've heard of and have used McCormick coatings but it was a long time ago and I've never used much of it. Since I barely remember it I assume it was neither crappy or spectacular BUT most paint brands have bad, good and best lines.
I don't recall ever hearing of a high build latex enamel.
Old 07-31-2019, 06:32 AM   #10
Rewards Points: 150
Old 07-31-2019, 06:42 AM   #11
retired painter
I don't know how much is the paint itself but I think the brush and brushing technique is also playing a part.
Gymschu and amospoint1978 like this.
Old 07-31-2019, 07:48 AM   #12
Rewards Points: 1,914
Behr has always been crap. You pay for the fancy marketing not high quality.
klaatu is offline   Reply With Quote
Old 07-31-2019, 07:50 AM   #13
High temp and dry brushing. Or crappy paint. OR all three for the WIN!
Old 07-31-2019, 08:06 AM   #14
Its all three. I guarantee I could make crappy paint look a lot better than that. I also know what paints to use to make it look even better, and most of them are specifically designed for trim. And, I use a nice, soft brush.
A chains only as strong as its weakest link.
amospoint1978 likes this.
Old 07-31-2019, 12:31 PM   #15
Rewards Points: 150
Interior conditioned space. I don't know what dry brushing is. The paint is a high end McCormick paint.
