Paint Blisters - Painting - DIY Chatroom Home Improvement Forum
Like Tree13Likes
  • 2 Post By lenaitch
  • 4 Post By Gymschu
  • 5 Post By joecaption
  • 1 Post By infoscout
Old 08-03-2018, 05:27 PM   #1
Rewards Points: 60
Paint Blisters
I painted a couple of 1" x 5 1/2" by 6' mahogany rails for a new porch. First I coated each rail with the spray version of oil-based Kilz Complete to contain any tannin leakage. Once it was good and dry, after very light sanding, I applied two coats (one day between coats) of latex exterior paint. They looked beautiful. No imperfections whatsoever. After a couple of weeks I installed them on the porch and they both (one more than the other) developed numerous small blisters. I sanded one rail and repainted with one coat of finish paint. It dried fine but then a couple of days later it blistered again. I also painted two smaller lengths of rail (for the section that angles down to the landing) and have had no problem at all with them. What's going on?!
infoscout is offline   Reply With Quote
Old 08-03-2018, 06:05 PM   #2
Rewards Points: 2,138
Re: Paint Blisters
is the blister down to the wood or just loss of adhesion to the primer? What kind of prep did you do before priming? The rails should be sanded 80-100 grit.
cocomonkeynuts is offline   Reply With Quote
Old 08-03-2018, 07:29 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,100
Re: Paint Blisters
I'm not familiar with painting mahogany but it might be that the wood was not sufficiently dry.
mark sr and cocomonkeynuts like this.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 08-03-2018, 08:56 PM   #4
Super Moderator
Gymschu's Avatar
Rewards Points: 558
Re: Paint Blisters
I'm gonna say that the spray can primer didn't "bite" onto the mahogany wood rails. When you applied the topcoats, they acted on the primer......the water in the latex pulled up the primer. Remember, spray cans of any kind of paint are very, very thin so that they can atomize through the nozzle. I would have recommended something like Zinnser CoverStain or really any quality oil primer not from a spray can.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 08-04-2018, 07:54 AM   #5
Rewards Points: 1,944
Re: Paint Blisters
KILZ! The joke that stays funny! For over 40 years! HAAHAA!
klaatu is offline   Reply With Quote
The Following User Says Thank You to klaatu For This Useful Post:
siffleur (08-04-2018)
Old 08-04-2018, 10:04 AM   #6
Rewards Points: 18,988
Re: Paint Blisters
I'm still trying to get over the fact that you even used Mahogany if it was just going to get painted.
Gymschu, lenaitch, mark sr and 2 others like this.
Old 08-04-2018, 04:16 PM   #7
Rewards Points: 60
Re: Paint Blisters
Just the top coats blistered. I sanded before applying Kilz and again lightly before apply the top coats. I suspect my problem has to do with moisture content.
Old 08-04-2018, 04:19 PM   #8
Rewards Points: 60
Re: Paint Blisters
Yeah, I think you're right. They should have been kiln-dried but the fact that the board used for the angled rails didn't blister and the one I used for the top most rails did makes me think it was moisture. I guess I give it a month or two to lose more moisture and then sand and paint again.
Gymschu likes this.
Old 08-04-2018, 04:24 PM   #9
Rewards Points: 60
Re: Paint Blisters
I figured someone would point that out. I didn't originally intend to use mahogany but it was cheaper than clear fir/spruce. I wanted something without knots that was hard and durable that was known for holding up well outdoors.
Old 08-04-2018, 04:27 PM   #10
Rewards Points: 60
Re: Paint Blisters
I noticed it was thin when I sprayed it on the board so I applied two coats of primer. The explanation makes sense except for the fact that the angled rails (used mahogany but a different board for those rails) didn't blister and I used the same painting process. Definitely will not use spray primer again though.
Gymschu likes this.
Old 08-04-2018, 06:26 PM   #11
Re: Paint Blisters
Teak is a very oily, dense wood that's why it's been used on boats for centuries.
Where on the planet are you that teak is cheaper then pine!
Around here it would have been at least $7.00 a ft.
Old 08-04-2018, 07:24 PM   #12
Rewards Points: 60
Re: Paint Blisters
Not teak. Mahogany. Teak was expensive like you stated. I got the mahogany for $2.30 a linear foot.
Old 08-04-2018, 08:40 PM   #13
Rewards Points: 214
Re: Paint Blisters
African mahogany is frequently used for painted exterior work, particularly on the higher end applications. Its is an excellent outdoor wood, should take paint well, and really isn't all the expensive (in contrast "genuine or Honduran mahogany which is significantly more). I just checked, and my normal dealer is $4.95/bd ft (4/4 fas). Narrow widths are available for under $2/bd ft.
There is definitely a part of me that cringes when I see it get painted though.
LanterDan is online now   Reply With Quote
Tags
blistering , blisters
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
