Must Smell Coming From Front Entry Fiberglass Door - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree15Likes
Old 05-20-2020, 08:27 AM   #31
Rewards Points: 22
Re: Must smell coming from front entry fiberglass door
Originally Posted by mark sr View Post
What I meant by latex paint 'breathing' a little is that vapors can pass thru latex coatings while it's very difficult for the vapors to pass thru solvent based coatings.
Is it better to use a foam roller for the primer as well or a brush or does it matter?
4rpr is offline   Reply With Quote
Old 05-20-2020, 08:47 AM   #32
retired painter
Rewards Points: 1,992
It doesn't matter. IMO brush looks better but that can be dependent on your brushing skills.
4rpr likes this.
mark sr is online now   Reply With Quote
Old 05-21-2020, 02:10 PM   #33
Rewards Points: 22
Question on how I should prep, prime and paint this cedar wood door trim on the exterior. This is our front door where there is a small porch so thereís an overhang.
Weird thing is the paint is chipping away only on this corner. The rest of the trim on the left, top and top right looks A ok. Itís just something with this corner.
Old 05-21-2020, 02:17 PM   #34
retired painter
That section probably sees more weather. I'd scrape/sand, prime and paint.
4rpr likes this.
Old 05-21-2020, 02:54 PM   #35
Rewards Points: 22
Any sandpaper I have laying around would be ok? I donít wanna overdo it.
Old 05-22-2020, 04:43 AM   #36
retired painter
80-120 grit, you want it to be rough enough to remove any loose paint and lessen the transition from sound to missing paint.
4rpr likes this.
Old 05-22-2020, 07:58 AM   #37
Rewards Points: 22
There shouldn't be any need to remove the existing paint - you can paint over it. Any oil base primer should seal any odors in the door or underlying paint. Pigmented shellacs like BIN are the ultimate odor blockers but I'd have a hard time believing that would be necessary.
Even after priming and painting ultimately since there will still be air trapped between the doors, wonít I need a primer like what you mentioned above (BIN) to completely avoid these musty odors from returning down the line? https://www.menards.com/main/paint/i...453-c-8028.htm
Or something like this: https://www.menards.com/main/paint/i...137-c-8028.htm
Because if I use this https://www.menards.com/main/paint/e...754-c-8013.htm
Iím afraid Iíll be faced with the same issue that I have now later on.
Thoughts?
Old 05-22-2020, 08:01 AM   #38
retired painter
BIN stops odor from coming thru whatever it's painted on, it won't prevent odor for developing over the paint or the paint applied over the BIN
Old 05-22-2020, 08:07 AM   #39
Rewards Points: 22
That was my thought, but over time even if I use a quality latex enamel paint Iím afraid because of the trapped air in this area, Iíll be faced with the same issue...over time with the musty smell coming from the actual door. Unless Iím wrong.
Old 05-22-2020, 11:34 AM   #40
Rewards Points: 56
Paint won't stick properly if it is too dirty. It would rather create a musty odor. You probably need a deep cleaning and paint is not the solution.
rmoore853 is offline   Reply With Quote
Old 05-22-2020, 11:37 AM   #41
Rewards Points: 22
I can always try to clean it and allow more air in. Problem is once the door closes over time in that day.... the smell comes back.
Plus the flat paint isnít what I wanted to keep in the long run. Semi gloss may be the way to go.
Old 05-22-2020, 12:43 PM   #42
Rewards Points: 22
Would it be a good idea to paint the sides and top white vs what is it now?
Old 05-22-2020, 01:08 PM   #43
retired painter
The top and bottom should be sealed, doesn't matter if it's paint or poly. The toe edge of the door [shown in the pic] gets painted/stained with the inside of the door. The heel edge [where the hinges are] gets painted with the outside of the door.
4rpr likes this.
Old 05-29-2020, 03:55 PM   #44
Rewards Points: 22
Primed it, but surprisingly the musty smell still prevails....Thoughts before painting? I use this: https://www.rustoleum.com/product-ca...killing-primer
Old 05-30-2020, 07:20 AM   #45
Rewards Points: 22
Are 2 coats of paint needed or is 1 ok? If it's 2 how long would I need to wait before applying coat 2?
Sent from my Pixel 3a using Tapatalk
