How To Turn Flat Paint Into Semi-gloss? - Painting - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 1 Post By ktownskier
  • 5 Post By XSleeper
  • 1 Post By SPS-1
  • 1 Post By jeffnc
Old 06-29-2020, 05:29 PM   #1
Rewards Points: 68
How to turn Flat paint into Semi-gloss?
Are ya' ready for this?. . .
What can I add to some Flat water-based paint, to make it Semi-gloss, or even Gloss?
Thanks, people.
Brass2312
Brass2312 is offline   Reply With Quote
Old 06-29-2020, 09:33 PM   #2
Rewards Points: 1,826
Re: How to turn Flat paint into Semi-gloss?
Not a gosh darn thing.
For example, in polyurethane, they take gloss poly and then add flattening agents to decrease the gloss.
They do something similar in flat paint. In a very simplistic way to describe it.
So, in other words, you wouldn't add anything to your paint, you would actually remove the flattening agents. That is if you could.
Brass2312 likes this.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 06-29-2020, 09:46 PM   #3
ZZZZZ's Avatar
Rewards Points: 2,810
Thanks, people.
Brass2312
Take some high gloss paint of the same type and color, mix it with the flat, and you will get something approaching semigloss.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is offline   Reply With Quote
Old 06-30-2020, 12:20 AM   #4
Rewards Points: 1,737
First you dump the flat paint out. Then you refill the can with semigloss or gloss paint. Problem solved.
SPS-1, mark sr, Brass2312 and 2 others like this.
XSleeper is offline   Reply With Quote
Old 06-30-2020, 05:17 AM   #5
retired painter
Rewards Points: 1,954
I've intermixed different paints a lot over the yrs and found that it doesn't take a lot of flat to lessen the the sheen of the paint. You'd think that half flat and half gloss would give you semi-gloss but that mixture would be closer to satin.
mark sr is offline   Reply With Quote
Old 06-30-2020, 06:21 AM   #6
Rewards Points: 198
Nothing really. You could increase the sheen by adding some acrylic resin, BUT the more you do that without adding pigment and/or flatting agents, the more transparent it becomes. It also would become thicker and need more water to be spreadable, thus diminishing hide even further.
There is a reason top shelf SG costs more than top shelf flat, it takes MORE resin AND higher quality pigment to get both sheen and hide.
RanK2 is offline   Reply With Quote
The Following User Says Thank You to RanK2 For This Useful Post:
Brass2312 (07-02-2020)
Old 06-30-2020, 06:39 AM   #7
Rewards Points: 10,796
Buy a can of semi-gloss. Use the flat for the first coat, and then the semi-gloss for the second coat. But make sure you get good coverage with the second coat, or you will be doing a third coat just to get an even surface.
mark sr likes this.
SPS-1 is offline   Reply With Quote
Old 06-30-2020, 09:07 AM   #8
Rewards Points: 4,194
Gloss to flat, a one way street.
Old Thomas is offline   Reply With Quote
Old 06-30-2020, 09:46 AM   #9
Rewards Points: 7,012
You can't make it gloss. To make it semi-gloss, you'd need to add so much gloss paint that it really wouldn't be worth it. Sounds like you're trying to save a few bucks which is nice but there's no useful way to do that.
RanK2 likes this.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 07-02-2020, 05:02 PM   #10
Rewards Points: 68
Thanks very much for the replies, people.
KTownSkier: I Really like your signature line about "The only stupid question is the one you DON'T ask!"
Seems like this was already a fairly Stupid question. But, I asked anyway. Ah, well.
XSleeper: Dam, THAT's Brilliant! WHY didn't I think of it?!
JeffNC: Yup, I was being the cheap bastard that I am. Sounds like it can't really be done.
OK, Thanks, anyway, people.
