How To Restain A Wooden Front Door With Rough Texture - Painting - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 07-31-2020, 06:24 PM   #1
Rewards Points: 36
How to restain a wooden front door with rough texture
Our wooden front door needs to be re-stained desperately. Typically, I would sand down the door and then stain, but the texture of the wood is rough and doesn't look like it would take well to being sanded. Could I apply a stain without sanding first?
Any ideas on how to brighten up the black kick plate that has dulled over time?
Thanks for the advice!
How to restain a wooden front door with rough texture-img_20200731_170717015.jpg   How to restain a wooden front door with rough texture-img_20200731_170740925_mp.jpg   How to restain a wooden front door with rough texture-img_20200731_170754577.jpg
coloradomtn is offline   Reply With Quote
Old 07-31-2020, 07:19 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 14,402
Re: How to restain a wooden front door with rough texture
Is it easy enough to take it off the hinges? That will be much easier on a set of saw horses.
Old 07-31-2020, 08:46 PM   #3
Rewards Points: 36
Unfortunately, not for me. I'm a 5ft nothing female so I think one of the doors weighs more than me.
Old 08-01-2020, 05:49 AM   #4
retired painter
Rewards Points: 462
I doubt the wood will take stain evenly without being sanded smooth first. How long has it been since the door was previously finished? If the color on the metal can't be restored with cleaning you'd need to paint them.
mark sr is online now   Reply With Quote
Old 08-01-2020, 07:24 AM   #5
Rewards Points: 19,092
It likely looks like that because it was allowed to go way to long before refinishing.
A Random orbital sander with 60 grit paper to start with would not take that long to get it flat again.
All that old sealer on the rest of the parts would also have to be sanded off before staining.
For a finish sealer the only one I would use is Bristol Finish.
http://bristolfinish.us/
It's avalible on EBAY and Amazon.
It's not cheap, but it for sure is the best.
It has 5 times the UV protection that Min Wax marine spar has.
It's self leveling, fast drying, high build up.
I would use no less the 3 layers of it for max protection.
That black piece at the bottom looks like a sweep, not a kick plate.
It could be cleaned, masked off then repainted, but then it would not match all the other oxidized metal.
mark sr likes this.
Old 08-01-2020, 07:30 AM   #6
Rewards Points: 7,046
The un-even ( splotchy ) degrading of the finish may prevent an even take on the new stain, but a more successful staining of a darker color might possibly overcome some of that. NOTE: SeniorSitizen said might.
Being Lacquer is a popular finish for manufacturers, even exterior being they don't care, at minimum i would give it a good cleaning with a well saturated lacquer thinner cloth and elbow grease before attempting a stain. Take safety precautions with the lacquer thinner, synthetic gloves and an abundance of air movement at minimum.
Edit: Edit:
Old 08-01-2020, 10:13 AM   #7
Rewards Points: 7,136
I think the easiest way to solve this would be to use the stain-and-poly-in-one formulas, such as
https://www.minwax.com/wood-products...wax-polyshades
jeffnc is offline   Reply With Quote
Old 08-01-2020, 10:15 AM   #8
They put a sweep at the bottom of the door divider too?
Old 08-01-2020, 10:17 AM   #9
That black thing is a Labyrinth seal.
Old 08-01-2020, 10:25 AM   #10
retired painter
Rewards Points: 462
Tinted polys have their place but can be difficult to apply correctly. It's easier to make a mess of it than do it right. AND tinted poly will do nothing to resolve the rough texture.
Old 08-01-2020, 10:30 AM   #11
No way would I ever use the suggested Polyshades for any project!!
I've tried it and it came out horrible and there's been hundreds of post about the bad results on this and any DIY site.
It also has no UV protection, and almost no wear protection.
Old 08-01-2020, 10:35 AM   #12
retired painter
Rewards Points: 462
I've used a good bit of tinted poly [mostly homemade] over the yrs. It is not forgiving but there are times when it's the best way to get the desired look. It's best to apply it over sealed wood [not raw wood trying to skip a step] and apply a coat of clear poly over it to protect the color from wear.
If I remember correctly PolyShades is rated for interior use only.
Old 08-01-2020, 11:47 AM   #13
First of all, I've used this product several times and it's always come out great. It's basically poly, and it's hard to imagine how you guys are having trouble applying poly.
With regard to the rough texture, that was the whole point of my suggestion - I said it was the easiest solution as it will go right over the rough texture with no sanding and refinishing required.
However, you are right that it's intended for interior use only - I forgot about that. So it's a non-starter.
Old 08-01-2020, 12:26 PM   #14
Rewards Points: 2,218
On rough surfaces soda blast, seal with shipnshore, apply stain, top coat with GF exterior 450 or equivilent spar varnish/urethane.
If you can't blast, clean the surface with a mild detergent, treat the black oxidzed parts with oxalic acid. gel stain, then top coat.
polyshades on an exterior door? no thanks.
cocomonkeynuts is offline   Reply With Quote
Old 08-01-2020, 01:41 PM   #15
Rewards Points: 36
Thanks everyone for the advice. The house is 8 years old and the door has never been restained. The rough texture of the wood is part of the design of the door and been like that since new. There are sections of the door where the wood is smooth and sections that have textured wood. The door has weathered over the years but the textures have stayed the same.
The soda blasting idea sounds interesting. I'll research this more.
In the meantime, I'll give the door a very good clean with mild detergent and treat the black metal with oxalic acid. If it comes up ok, I'll likely try a gel stain and top coat. It was good to read that gel stains don't require you to sand the door back to it's original wood.
