How Many Coats Of Trim Paint? - Painting - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By willc86
Old 03-23-2016, 09:52 PM   #1
Rewards Points: 398
How many coats of trim paint?
I recently hung new wall opening casing around my dining room entrance. Pre-primed white pine molding.
I nailed it in place, wood filled the nail holes and caulked the edges. I then sanded it down buttery smooth, wiped it down and added two coats of 123 primer 24 hours apart.
I just did my first coat of BM Advanced Satin trim paint and it looks pretty good to me. Should I add a second coat of that as well or is one generally sufficient (24 hours later)?
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 03-24-2016, 01:45 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 28
Re: How many coats of trim paint?
Always 2 finish coats, one primer would have been enough.
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (03-24-2016), ToolSeeker (03-24-2016)
Old 03-24-2016, 03:11 AM   #3
Rewards Points: 2,362
FrodoOne is offline   Reply With Quote
Old 03-24-2016, 07:00 AM   #4
Jmayspaint's Avatar
Rewards Points: 538
Best to put another finish coat on. Even if it looks solid and covered well because of the double primer coat, you won't get maximum durability out of it with only one finish.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Old 03-26-2016, 08:54 AM   #5
Rewards Points: 74
i ususally start with a primer and let it sit for a day, then 1 coat sit for a day then another coat next day - prior its not a dusty area or high substance area.
if not - your regular drying time works as well, but waiting an entire day I noticed paint holds up much longer
rhudson123 likes this.
willc86 is offline   Reply With Quote
The Following User Says Thank You to willc86 For This Useful Post:
rhudson123 (06-04-2016)
Old 03-26-2016, 09:23 AM   #6
Rewards Points: 398
Thanks - I did the second coat. Each coat (primer and paint) had 24 hours drying time between each.
The Following User Says Thank You to adgjqetuo For This Useful Post:
Gymschu (03-26-2016)
How to paint the walls? AlbertCitiz Painting 4 03-14-2016 04:40 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 12:25 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
