Gaps In Cedar Porch Column - Caulk Or Filler? - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 06-27-2016, 08:57 PM   #31
Super Moderator
Gymschu's Avatar
Rewards Points: 6,624
Re: Gaps in cedar porch column - caulk or filler?
Job well done, cjaustin. Nice to hear a success story on here from advice given.........
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following User Says Thank You to Gymschu For This Useful Post:
cjaustin81 (06-27-2016)
Old 06-27-2016, 10:07 PM   #32
Rewards Points: 1,099
Thank you, I appreciate all the help you personally devote in these threads.
For anyone looking for a very expandable caulk.. the Tower Tech 2 worked wonders. Much better than the DAP Dynaflex.
Gymschu likes this.
cjaustin81 is offline   Reply With Quote
Old 06-27-2016, 10:13 PM   #33
Originally Posted by ChiTownPro View Post
Pull them off, clean them up, prime all sides, glue and nail them back in place.
This was the solution.
After pulling them off, cutting new pieces and then priming ALL sides, followed by cedar galvanized anti-split nails (after I pre-drilled the nail holes to prevent cedar splitting)
The Following User Says Thank You to cjaustin81 For This Useful Post:
ChiTownPro (07-05-2016)
Porch column base rotted RickO General DIY Discussions 17 10-25-2011 08:43 PM
Stone or Block Porch Column Scoob66 Building & Construction 0 05-23-2010 11:48 PM
Removal of Porch Column sjsdesigns Building & Construction 4 04-12-2010 07:48 PM
Replace Rotting Porch Column? Dazed&Confused General DIY Discussions 7 09-30-2008 04:44 PM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 12:29 PM
