Exterior Concrete Stain - Painting - DIY Chatroom Home Improvement Forum
Old 04-15-2019, 10:07 AM   #1
still igneous
Rewards Points: 36
Exterior concrete stain
My concrete porch floor is 12 years old and has never been treated. It looks fine except for a couple of rust spots that I can’t remove. My question is whether to use a water borne stain or solvent based. I asked a similar question a while back about my deck. I’m concerned about what future maintenance will involve. I remember you guys talking about stain penetrating the surface vs forming a film that may peel. Is the same true for concrete?
luv2paint is offline   Reply With Quote
Old 04-15-2019, 11:27 AM   #2
retired painter
Rewards Points: 1,772
Re: Exterior concrete stain
I've had good results using H&C concrete stain [solid color] While it comes in both waterborne and solvent based [xylene if I remember correctly] I've only used the solvent based version. Their solvent stain will wear away but it recoats nicely with the next coat 'melting' the existing to create a great bond.
mark sr is offline   Reply With Quote
Old 04-15-2019, 11:49 AM   #3
retired framer
Rewards Points: 10,532
Floor neutralizer will remove rust, but if the concrete has other colours trowelled into the surface it will remove that too.
Do not use flat bottom gables with scissor trusses.
Old 04-15-2019, 03:04 PM   #4
still igneous
Rewards Points: 36
What is floor neutralizer and where can I find it? Thanks for reply.
Old 04-15-2019, 03:52 PM   #5
Super Moderator
Gymschu's Avatar
Rewards Points: 6,542
I use the H&C water-based version of their concrete stain and it has been amazing on my patio which is in full sun all day and also takes a beating from the weather. My only prep was pressure washing. It has been 8 years since I did a full re-coat. There are a few areas of wear due to foot traffic and snow shoveling, but, aside from that, it still looks good. Gonna re-coat it this summer.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 04-15-2019, 04:04 PM   #6
retired framer
I don't know much about it but when we asked about rust on the drive way, one of the box stores sold us something called floor neutralizer and it worked. I think HD sells a product.
Here is some info.
https://www.factorydirectchemicals.c...dues-4-gallons
Douglas Fir exterior door. Looking for stain that I can paint over if stain looks bad jkeuning Painting 1 10-08-2016 07:57 AM
Need some advice on how to stain deck after repairs pasalott Painting 3 07-18-2016 09:56 AM
Can I add color with acid stain over concrete stain? mandig3 Painting 2 06-04-2013 09:30 PM
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 01:57 PM
