Can Light Trim Painting - Painting - DIY Chatroom Home Improvement Forum
Old 11-22-2015, 09:07 AM   #1
Rewards Points: 1,254
can light trim painting
i have led's like these in my kitchen ceiling . they are white. i want them to be brown. i have 2 cans of spray enamel paint, gloss and satin.
which do you think i should use, and why ?
it is probably person preference , but there may be some issue i am not seeing as to one vs the other.
http://www.geoffwilliamselectric.com...-inch-trim.jpg
Fix'n it is offline   Reply With Quote
Old 11-22-2015, 09:14 AM   #2
white = uggg
Old 11-22-2015, 09:24 AM   #3
blackjack's Avatar
Rewards Points: 108
I'd prime them and paint the rings to match the ceiling.
blackjack is offline   Reply With Quote
Old 11-22-2015, 12:54 PM   #4
JUSTA MEMBER
Rewards Points: 3,922
Gloss Enamel will be shiny, and cause odd reflections from any other light source.
I vote satin, after a decent primer.
ED
de-nagorg is offline   Reply With Quote
Old 11-22-2015, 07:17 PM   #5
i was planning to do this today. but grouting my kitchen floor and rearanging the living room took my time.
so more opinions are welcome
Old 11-23-2015, 12:14 AM   #6
Rewards Points: 234
I would be inclined to paint the ceiling white, so there is a uniform field of white overhead. Or paint them a beige which matches the current ceiling color. But I realize that is not what you are after.
Between satin and gloss, I would also choose satin for appearance.
RustNeverSleeps is offline   Reply With Quote
Old 11-23-2015, 07:14 AM   #7
Rewards Points: 30
Originally Posted by RustNeverSleeps View Post
I would be inclined to paint the ceiling white, so there is a uniform field of white overhead. .... Between satin and gloss, I would also choose satin for appearance.
I would do the same. That's a nice and glossy non-white ceiling. While you're at it, replace the surface light above the sink.
If you really want a beige ceiling. Match that trim imho.
bmathews is offline   Reply With Quote
Old 11-23-2015, 07:33 PM   #8
white ceiling = not me. the color there is correct, for now. but was the wrong sheen. but thats ok, it all needs another coat anyway.
that light, i just threw that up there cause i had it. once the kitchen is mostly done i will pick out something goes with it all.
ok, i think i will try the satin and see how it looks.
The Following User Says Thank You to Fix'n it For This Useful Post:
de-nagorg (11-23-2015)
Old 11-28-2015, 08:24 AM   #9
update, kinda.
yesterday i painted one of them, interesting results.
pics and review later.
de-nagorg (11-28-2015)
Please review my sequence for painting and trim work....New Construction homeby5 General DIY Discussions 12 07-28-2015 09:27 PM
removing recessed light trim that is wired on Jbland Electrical 4 09-14-2011 01:32 PM
painting a room with oak trim Joline Painting 1 09-05-2011 03:40 PM
Painting over trim wriegler Painting 2 11-22-2010 11:40 PM
Advice needed for Exterior Trim painting fordman289 Painting 2 07-16-2009 01:10 PM
