Can I Paint The Popcorn Ceiling... - Painting - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By mark sr
  • 1 Post By mark sr
  • 1 Post By ZEW496
Old 01-23-2020, 10:54 PM   #1
Rewards Points: 2
Question
Can I paint the popcorn ceiling...
Renting here, popcorn ceiling dirty and dark, can I prime and paint it without much brushing off of the dust?
clsteele11 is offline   Reply With Quote
Old 01-23-2020, 11:09 PM   #2
Rewards Points: 4
Re: Can I paint the popcorn ceiling...
Iíve done my house and a reno house. Trick is not to go back and forth like painting walls. Buy the ceiling paint for popcorn and use a thick pile roller. Yes it stinks but only lasts a day. Two coats will be required and second coat is applied opposite the first coat.
Retired guy from Southern Manitoba, Canada.
660catman is offline   Reply With Quote
Old 01-24-2020, 12:43 AM   #3
Rewards Points: 5,012
Some popcorn ceilings are not done with water but actual paint and they won't flake off.
If it's been done with water rent a low pressure paint sprayer and save yourself some heartache. Just use ceiling paint.
ron45 is offline   Reply With Quote
Old 01-24-2020, 05:41 AM   #4
retired painter
Rewards Points: 1,806
Painting old popcorn can be tricky. Old unpainted popcorn is prone to partially dissolve from the moisture in latex paint or primer and then fall off of the ceiling [usually just in spots] There are 2 work arounds; spray the paint [but not too heavy] or coat it first with an oil base primer.
Since you are renting make sure you consult the landlord first!
weatheredwood and Gymschu like this.
mark sr is online now   Reply With Quote
Old 01-24-2020, 09:06 AM   #5
Mystriss's Avatar
Rewards Points: 4,896
Make sure you ask your landlord if you can paint it.
That said, get an extendable paint stick and some high nap rollers and have fun! Be sure to cover /everything/ with a sheet of plastic, paint goes everywhere when rolling :P
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 01-24-2020, 02:10 PM   #6
retired painter
We call them roller poles. I have both wooden ones and aluminum extendable ones. I couldn't imagine rolling on paint without one!
Mystriss likes this.
Old 01-24-2020, 08:37 PM   #7
Mystriss's Avatar
Nice to have the professional name for it!
Mine is this one - https://www.grainger.com/product/12G...200125013701:s
I love using it for ceilings because you can easily shorten it to reload paint - and it feels nice on the hands too
Old 01-25-2020, 10:56 AM   #8
Super Moderator
Gymschu's Avatar
Rewards Points: 312
+1 on checking with the landlord. I mean, even if your intentions are good, well, you could end up with quite a problem if the popcorn peels off (and about 1/2 the time it does). Now, the landlord has to bring in someone to remove the mess you created and redo the ceiling. Popcorn also soaks up the paint. Buy about twice as much as you would for a normal flat ceiling.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 01-26-2020, 01:04 PM   #9
Rewards Points: 1,148
As others have mentioned, if you are renting, best to ask the landlord before doing any painting. In fact, get permission in writing. Often there are restrictions on tenants doing any painting written into the lease.
Personally, I would advise against a tenant attempting to paint a popcorn ceiling in a rental. It's a crap shoot. You can do everything right and still things can quickly go bad. Then, somebody will be responsible for repairing the damage, and most likely it won't be the landlord.
Gymschu likes this.
ZEW496 is offline   Reply With Quote
Tags
ceiling , paint , popcorn
