A Snow Primer - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Like Tree37Likes
Old 11-28-2019, 09:55 PM   #1
Rewards Points: 514
A Snow Primer
I realized yesterday how little I remember about snow. Born & bred in So. California, we visited snow in the mountains. I spent a year in Omaha but only remember frozen 'wet' hair, black ice, lots of time indoors and the pain of not wearing enough clothes when outside.
What are the signs of snow? I saw snow on the Coastal Mountains, yesterday. It's supposed to be 27 degrees F tonight. Does that mean snow if it rains?
I know the signs of rain in the distance, when you see a solid sheet of gray from clouds to ground. Yesterday, there was a solid sheet of black in the Coastal Mountains. Is that snowfall?
I know some will laugh but I really am clueless. And cold.
DoomsDave likes this.
Nik333 is online now   Reply With Quote
Old 11-28-2019, 10:15 PM   #2
retired framer
Rewards Points: 4,616
Re: A Snow Primer
Yes it is just like rain and you can see it in the distance if it not snowing where you are.
A black sheet like that was likely snow.
de-nagorg and Nik333 like this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
Nik333 (11-28-2019)
Old 11-28-2019, 10:21 PM   #3
Rewards Points: 514
Re: A Snow Primer
Do you know what makes it look black? Some trick of light on crystals?
Old 11-28-2019, 10:23 PM   #4
Rewards Points: 7,734
Re: A Snow Primer
Black ice is a combination of cold surface temperatures and a light (cold) rain. With today's radar weather I no longer rely on the height of the bees nests or amount of pine cones to predict winter. Weather forecasting can add it all up from moisture to temperature at all levels and predict what is coming even when nothing bad is showing on the horizon.
As for staying warm one of the groups I have worked with are those stuck in old poorly insulated homes with expensive heat. One solution is to create a warm spot where you can retreat and get warm.
Bud
gma2rjc and Nik333 like this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 11-28-2019, 10:38 PM   #5
JUSTA MEMBER
Rewards Points: 1,084
Re: A Snow Primer
At least you admit it. :vs_la ugh:
Some of us can smell it on the wind.
That takes experience.
Yes a dark bank in the direction of the prevailing wind in the winter, indicates snow, and usually lots of it.
Get yourself an electric blanket, and bundle up in it.
There has been an accumulation of a foot, so far this season here, and more predicted for the next two days.
And for goodness sake, stay off the roads as much as possible, 99% of those California drivers don't know how to drive in it, and we don't want to lose you to idiot drivers.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Nik333 (11-28-2019)
Old 11-28-2019, 10:43 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 706
Re: A Snow Primer
If you mean why does a distant snow squall appear dark in the sky, yes, it's the same as a rain squall. Visibility distance is shortened and ambient light is reduced by the moisture (rain drops, snow flakes) in the air.
Startingover, de-nagorg and Nik333 like this.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Nik333 (11-28-2019)
Old 11-28-2019, 11:01 PM   #7
Rewards Points: 514
Re: A Snow Primer
I forgot I lived in Seattle. I remember wondering why they called certain areas 'hills' when there didn't seem to be a hill.
I found out when I slid backwards on an icy hill. At least I had a Jeep.
This is unusually chilly. An almond farmer told me there is usually only freezing weather for a short time in Jan or Feb.
I can feel cold air coming thru the air conditioner.
Edit: Ok, I taped a plastic bag over the A/C to block the breeze.
I turned off the electric heater that had a fan drawing in air & blocked the gap under the door with foam.
Startingover and de-nagorg like this.
Old 11-28-2019, 11:10 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 706
Re: A Snow Primer
If it looks like the cold spell is going to hang around, cover your a/c with a garbage bag and some duct or even packing tape. It won't insulate the unit but it will keep the cold air from coming through.
It can be a challenge for areas that don't normally experience cold, wintry weather. Buildings and civic infrastructure aren't designed for it and folks aren't usually skilled in how to deal with it.
Sic Itur ad Astra
Old 11-29-2019, 08:00 AM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,366
Re: A Snow Primer
Sliding backwards on a icy hill. Reminds me of living in Calgary.
Winnipeg is pretty flat but yeah I would hate to live in a very hilly snowy area permanently.
This video is from a Russian guy and enjoy the slide/ride.
Some of it is from North America too. You can see a big ole Ford Bronco which they don't have in the first part.
Dave Sal, Nik333 and Nealtw like this.
Old 11-29-2019, 09:39 AM   #10
Rewards Points: 3,234
Re: A Snow Primer
Bud
That warm spot was the living room where Dad had the wood stove pipe cherry red up about 3 ft. That room was the only one large enough to accommodate all of us.
SeniorSitizen is offline   Reply With Quote
Old 11-29-2019, 10:02 PM   #11
DoomsDave's Avatar
Rewards Points: 8,434
Re: A Snow Primer
Lawdy miss clawdy.
Bumper hitching, in the snow.
yuri and de-nagorg like this.
Suffer not a fool, look not in the mirror.
Life is one long teaching moment.
DoomsDave is offline   Reply With Quote
Old 11-29-2019, 10:05 PM   #12
DoomsDave's Avatar
Re: A Snow Primer
https://youtu.be/kN3Y0kyBrzQ
I want my mommy.
Pittsburgh Pennsyltucky in the winter, wanna scream.
Those vids coulda' been in APRIL not joking.
California's EXPENSIVE.
Worth it.
de-nagorg likes this.
Old 11-29-2019, 10:13 PM   #13
Rewards Points: 514
Re: A Snow Primer
Originally Posted by DoomsDave View Post
I want my mmmy.
Worth it.
Where are you moving to?
Old 11-29-2019, 11:20 PM   #14
JUSTA MEMBER
Re: A Snow Primer
Lawdy miss clawdy.
Now that is just dangerous.
Here about 40 years ago, a young man was towing his younger brother on a car hood, behind his pickup, the driver had to stop suddenly, but the "sled" did not, it slid up under the truck, De-capitated the little brother.
Older brother was not "right" after that.
A tragedy really.
ED
Old 11-30-2019, 07:29 PM   #15
DoomsDave's Avatar
Re: A Snow Primer
Nowhere for now.
