Anyone Know What This Is? - Off Topic - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Chatroom Community > Off Topic
Like Tree9Likes
  • 5 Post By ZZZZZ
  • 3 Post By SeniorSitizen
  • 1 Post By GrayHair
Old 04-20-2020, 10:39 AM   #1
Rewards Points: 6,554
Anyone Know What this Is?
This appears to be mounted on a 2x4 door jamb of a 1 room school that was built in 1896 and closed in 1948. It does not pivot where it is attached to the 2x4. Centered between the springs is a cylinder so my first thought was a door closer of some sort. Not to confuse with the subject in question, in the upper right that's a utility pole that has the X drawn across.
Old 04-20-2020, 10:41 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,996
Re: Anyone Know What this Is?
Looks like some sort of shock absorbing bumper, possibly from an antique car or tractor.
Old 04-20-2020, 10:48 AM   #3
retired framer
Rewards Points: 15,658
trailer hitch ??
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 04-20-2020, 10:59 AM   #4
ZZZZZ's Avatar
Rewards Points: 2,904
Is it part of a rack device to make short kids taller?
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is offline   Reply With Quote
Old 04-20-2020, 01:51 PM   #5
DoomsDave's Avatar
Rewards Points: 14,230
@SeniorSitizen , does that spring thing have a name stamped on it, maybe by the manufacturer?
Life is one long teaching moment.
DoomsDave is offline   Reply With Quote
Old 04-20-2020, 02:07 PM   #6
retired framer
We can see what it does, the question is why?
figure 7-14
Old 04-20-2020, 05:09 PM   #7
Door Closer, found by a nephew to make uncle SeniorSitizen happy. To the best of my knowledge it was installed on the door when the school building was built in 1896. Thanks All
The pic is of a salesman's sample.
http://web.archive.org/web/201601171...lam/index.html
ZZZZZ, Nealtw and DoomsDave like this.
Old 04-21-2020, 08:25 AM   #8
DoomsDave's Avatar
Kant-Slam!
Hmm. Take that to a punk rock dance . . . . .
Old 04-21-2020, 05:30 PM   #9
GrayHair's Avatar
Rewards Points: 1,450
Dang, I must be old. I recognized it immediately.
Nik333 likes this.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
