Removing Steam Radiator - New Member Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > New Member Introductions
Old 05-08-2011, 07:15 PM   #1
Removing steam radiator
I am trying to remove a steam radiator for our flooring people that are coming. I have closed the intake valve and removed the upper pipe. the lower pipe seems to be vice like stuck. Looking at the threads makes no sense on which way to turn them. if i attempt to back-off the threads on any one of the 2 available turn points, they seem like they would tighten on to the previous one. and i cant seem to turn them at all. like they are stuck. any ideas on how to release this pipe from the radiator?
jonny1968 is offline   Reply With Quote
Old 05-08-2011, 07:20 PM   #2
Learning by Doing
Leah Frances's Avatar
It goes the wrong way - it's how most steam rads are. You're tightening it instead of loosening it. it's contrary to righty-tighty and therefor not exactly intuitive.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
jonny1968 (05-08-2011)
Old 05-08-2011, 07:30 PM   #3
turning it opposite, still seems to be stuck. I suppose from being attached for so long. Would heat from a torch be normal practice to remove such a fitting?
Old 05-08-2011, 08:28 PM   #4
Learning by Doing
Start with lots of PB Blaster.
I had a crew replace all my supply valves and they just tore the old fittings off with a giant pipe wrench and two guys hauling on it. Then they replaced them. The bungs they muscled out too, but they also had to be replaced due to damage of removing them.
Tough job. Get yourself some spare parts and a REALLY big wrench.
Old 05-08-2011, 09:07 PM   #5
Missouri Bound's Avatar
Rewards Points: 2,464
You will need to cut the copper, then re-solder after the job is finished.
Missouri Bound is online now   Reply With Quote
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
jonny1968 (05-08-2011), oh'mike (05-08-2011)
Old 05-08-2011, 09:18 PM   #6
Cut copper pipe
Thank you all for your help. I am new at this steam heat thing. I am going to cut the pipe. do I need to relieve pressure or drain the tank downstairs? There is no valve to stop water from leaking back out of the exit pipe. I will need to keep the floor as dry as possible for the wood floor install.
Old 05-08-2011, 09:21 PM   #7
BIGRED
Rewards Points: 252
Missouri Bound hit the nail on the head !! There is no radiator union shown in this photo so the easiest way to remove this radiator is to cut the copper in the hub area of the copper fitting and sweat the cut copper hub off the pipe. Sweat the new fitting on on the copper first and when cool dope and tape the threads and screw the fitting into the radiator. Then sweat the other end of the copper pipe into the nearest coupling or 90 on that run if you are not going to put in any radiator unions.
Grampa Bud is offline   Reply With Quote
remove steam radiator rick2665 HVAC 11 03-09-2010 08:29 PM
Converting a steam radiator to hot water mnp13 HVAC 0 02-03-2010 05:28 PM
Steam Radiator in Hot Water System whitesjtaa HVAC 4 01-11-2010 09:32 PM
Removing a Cast Iron Radiator MugsynSax Plumbing 1 10-05-2009 05:18 PM
Steam Radiator Making Hammering Noise farooq Plumbing 4 10-06-2008 12:02 PM
