Kitchen Backsplash Question - New Member Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > New Member Introductions
Like Tree4Likes
  • 4 Post By chandler48
Old 12-23-2019, 06:31 AM   #1
Rewards Points: 2
Kitchen backsplash question
Replacing tired and old kitchen marble countertop and backsplash with new granite countertop and subway tile backsplash. I am trying to avoid the removal of the marble tile backsplash glued on the drywall and want to subway over the marble. My first question is what product or products are advised to adhere the subway over the marble.
My second question is related to the removal of the marble countertop which will create a one to one and a half inch gap between the new granite top and the exposed marble backsplash so I will need to apply a filler to fill this gap and be able to apply the subway backsplash once the filler is dry. What product's should I use for this part of the project?
THANKS
mickeymouse204 is offline   Reply With Quote
Old 12-23-2019, 06:38 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,254
Re: Kitchen backsplash question
From what you are describing it won't go well. What do you propose to do with the ends of the back splash once they are built out. Are they exposed? I would remove all the old back splash, skim coat the sheetrock behind it, or even replace it, then install the back splash of your choice. That will give you a classic look without cobbling it together.
Dave Sal, Colbyt, mark sr and 1 others like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
mickeymouse204 (12-23-2019)
Old 12-23-2019, 08:19 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,370
Welcome to the forums.
Old 12-23-2019, 08:40 AM   #4
JUSTA MEMBER
Rewards Points: 1,470
I too advocate that you just "Do it right the first time", and tear out the existing backsplash and it's "rock" sheeting.
That way you can start over from the studs, and add ,or remove outlets / switches wherever SWMBO wants them.
May be more work for you, but the results are more satisfying.
ED
de-nagorg is online now   Reply With Quote
Tags
backsplash , kitchen , marble tile , subway tile
