Hello From GA. Going To Need Alot Of Advice. - New Member Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > New Member Introductions
Old 06-17-2015, 05:26 AM   #1
Rewards Points: 18
Hello from GA. Going to need alot of advice.
Hi all, Im new to these forums but I think that this is awesome. But Ill get straight to it. I am medically retired from the military and have been renting houses my whole life. Well my inlaws cutoff half of their property to me and the wife to build on. Well she found a deal on a older model double wide that needed some work. But for the price well you cant beat free. Just the cost of moving it. Well so far I have done all the work myself, completely gutting it out to bare stud walls. Electrical gone, plumbing gone, etc... Ive come a long way on it, but have a lot more to go. Im pretty knowledgeable on most construction related, but now to the point of I need help and cant really get it. So maybe verbal help can do just as good. Im working on electrical right now, which isn't too much of a headache yet. But we'll see what happens. I look forward to getting some good advice and hearing what others have to say.
crarow84 is offline   Reply With Quote
Old 06-17-2015, 11:41 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 284
Glad to have you with us, if we can help just let us know.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-17-2015, 11:47 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 10,046
Thank you for your service to our country and welcome to to the group.
Post pics....we love giving out advice when someone else is doing the work.
Old 06-22-2015, 11:10 AM   #4
Rewards Points: 1,910
Thanks for your service. May I recommend that you do plumbing first, then Hvac, then wiring.
The reason being that plumbing can't be routed around obstacles as easily because drain water must flow downhill; air duct is also hard to route around obstacles but slightly easier because air can be blown up hill or downhill; Wiring can go around everything easily.
If you do wiring first you may well run wiring through a space that you will want to run a drain pipe or air duct and you'll need to rewire that section.
Old 06-23-2015, 01:05 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,748
Welcome to the forums and as ddawg said, thank you for your service.
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
