Building A Corner Workstation - New Member Introductions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > New Member Introductions
Old 12-19-2018, 01:34 PM   #1
Rewards Points: 4
Question
Building a Corner Workstation
I saw a MICKE Corner Workstation on Ikea. It shows dimensions and a how to for building. The desk costs $150. Would it be cheaper to just build it myself with wood from Home Depot cut to the correct sizes and shapes?
AdiTwo82 is offline   Reply With Quote
Old 12-19-2018, 02:39 PM   #2
HenryMac's Avatar
Rewards Points: 1,006
Re: Building a Corner Workstation
Cheaper? Probably not.
https://www.ikea.com/us/en/catalog/products/50244741/
HenryMac is offline   Reply With Quote
Old 12-19-2018, 02:52 PM   #3
retired framer
Rewards Points: 15,368
You won't have all their little hardware pieces so you would have to do a lot more to make it sturdy, when all is said and done you would have trouble beating their price I think.
The Following User Says Thank You to Nealtw For This Useful Post:
AdiTwo82 (12-21-2018)
Old 12-21-2018, 11:36 AM   #4
Rewards Points: 4
I was planning on basing it on the Ikea workstation, but using actual screws, etc. instead. With this in account, do you still think it costly?
Old 12-21-2018, 11:47 AM   #5
retired framer
Their junky little hardware bit actually hold things better than screws, so you would have to redesign it with cleats. You would likely build it better than theirs but time and materials
How many sheets of plywood would you need.
https://www.homedepot.com/p/PureBond...3012/100548908
Old 12-21-2018, 12:23 PM   #6
Rewards Points: 10,798
No. Would be far more expensive. You get to say you did it yourself, which is definitely worth something. But you will spend more for sure.
Those sizes will have to be cut from sheet. Maybe somebody here can make veneered plywood look that good, but its not me. I would be putting high pressure laminate on it. Start pricing out just a couple of sheets of wood, a few sheets of laminate, a gallon of contact cement, a good roller...
Then again, that photo may look too good. Wonder if the real thing looks that good.
SPS-1 is online now   Reply With Quote
Tags
building and construction , diy advice
glue corner beads and tape? begal Drywall & Plaster 16 04-09-2017 07:22 PM
Re: old buildings RWolff Building & Construction 157 01-19-2014 12:35 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
