System Not Doing Quotes Properly - Site Help and Suggestions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Forum Support > Site Help and Suggestions
Old 01-06-2020, 04:17 PM   #1
An old Tradesmen
Rewards Points: 8,518
System not doing quotes properly
Quotes isn't workin right.
Link to one of the incorrect quotes.
https://www.diychatroom.com/f112/act...4/#post6026843
Old 01-06-2020, 04:29 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,110
Re: System not doing quotes properly
Not sure what went wrong but I inserted the missing start of quote tag for the second quote.
Old 01-06-2020, 04:41 PM   #3
An old Tradesmen
I was leaving it as it was. So the I T guys could see what it was doing.
Old 01-06-2020, 04:45 PM   #4
retired framer
Rewards Points: 4,588
I have seen that on a few quotes for a couple days, not sure where.
Do not use flat bottom gables with scissor trusses.
Old 01-06-2020, 04:53 PM   #5
Super Moderator
joed's Avatar
I fixed it before reading this post.
For the IT guys all I did was add the opening {quote} tag for the start of the second quote on the two posts I edited.
The Following User Says Thank You to joed For This Useful Post:
Admin (01-08-2020)
Old 01-08-2020, 11:15 AM   #6
Administrator
Admin's Avatar
Rewards Points: 1,310
we might need some more examples first. not sure what's going on here.
some work but some don't?
Lee
Admin is offline   Reply With Quote
Old 01-08-2020, 12:12 PM   #7
Super Moderator
joed's Avatar
Could it be related to double quotes in the same post? The posts I fixed could possibly have originally been quote within a quote.
Old 01-09-2020, 09:19 PM   #8
Administrator
Admin's Avatar
The first post you quoted in your post has a random half of a quote bbcode within it, which was caused the messiness. Don't know why it's there, but I would assume by accident
Post 43: https://www.diychatroom.com/f112/act...3/#post6026759
Kevin
Old 01-09-2020, 09:28 PM   #9
Super Moderator
joed's Avatar
More than just post #43. Several before it also have the issue. What i did to fix a couple of them was to add the apparently missing opening quotes BB code. The end quote does appear to end an actual quote from a previous thread.
Old 01-10-2020, 05:06 AM   #10
An old Tradesmen
The few I fixed, I just removed the extra end quote marker.
Old 01-10-2020, 05:16 AM   #11
retired framer
I quoted yesterday and noticed the post quoted was something else and read like it was from the CBR, so I started over and it worked right the next time. I went looking for the posts that had come up and couldn't find it so it must be from further in the past, so it wasn't anything I did.
Old 01-13-2020, 04:24 PM   #12
Administrator
Admin's Avatar
I can't figure out the why with what I got so far. I'll need a couple more examples to look at. If anyone gets me one, I'll as be interested in knowing what device and browser you are using
Kevin
