Why Is My Miter Saw Blade Heating Up - Tools - DIY Chatroom Home Improvement Forum
Old 12-19-2015, 05:46 PM   #1
Rewards Points: 356
Question
Why is my miter saw blade heating up
I have a Craftsman 10" miter saw (no more than 2 years old) I have been having trouble with the blade consistently heating up and burning the material. Right now I am doing nothing but cutting 1/2 inch think baseboard yet I am still having the problem. I just bought a new blade because I thought the old one might be dull but that did not help. Any assistance is appreciated.
tripower is offline   Reply With Quote
Old 12-19-2015, 06:14 PM   #2
Civil Engineer
Rewards Points: 5,246
I only use carbide tipped blades in my mitre saw and table saw, they hold their edge much longer than steel blades. The most common cause of heating is a dull blade, but you say you got a new one and it still heats. Another possibility is that you are using a blade that is not intended for a mitre saw (wrong tooth configuration). If you are using the correct blade and it is sharp, you need to check to make sure the saw is adjusted correctly. You need to read the manual on adjustments, but generally there are several nuts or screws that are turned to make sure the blade is square in the 90 degree position, and the track is straight.
Old 12-19-2015, 08:06 PM   #3
kwikfishron's Avatar
Rewards Points: 144
Are you sure that you didn't put the blade in backwards?
kwikfishron is offline   Reply With Quote
The Following 3 Users Say Thank You to kwikfishron For This Useful Post:
BigJim (01-12-2016), oh'mike (12-20-2015), Yodaman (12-19-2015)
Old 12-19-2015, 08:49 PM   #4
Rewards Points: 18,230
How many tooth blade are you trying to use?
What brand blade did you buy?
The adjustments on the saw have nothing to do with causing the wood to burn.
Old 12-19-2015, 09:26 PM   #5
Property Mgt/Maint
Rewards Points: 7,388
post a close up pic of the blade on your saw
[political signature removed]
Yodaman is online now   Reply With Quote
Old 01-11-2016, 09:15 PM   #6
Rewards Points: 82
Can you post the blade of mitre saw and burned material?
cmorales is offline   Reply With Quote
Old 01-12-2016, 01:41 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 494
He must have found the problem, he hasn't posted since the 19th of last month, I kinda think like Ron, the blade was on backwards. I have seen that happen before.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
oh'mike (01-12-2016), Yodaman (01-12-2016)
Miter saw issues - cracked blade? LanterDan Tools 10 04-17-2015 08:06 PM
Best Miter Saw Blade for Cabinets / Trim Scottg Tools 11 03-20-2015 09:16 PM
Miter Saw Advice (Sliding vs. Non-sliding) theOptimizer Tools 20 01-26-2015 12:29 PM
Picture Frame with Miter Cuts wkumtrider Carpentry 11 01-19-2015 07:55 PM
Removing a blade from an old Craftsman Circular Saw Davem720 Tools 1 07-05-2010 10:17 PM
