Router Bit Size Too Big For Router? (Porter Cable 690LR) - Tools - DIY Chatroom Home Improvement Forum
Old 11-30-2015, 08:43 PM   #1
Rewards Points: 414
Router bit size too big for router? (Porter Cable 690LR)
I have this router:
http://www.amazon.com/PORTER-CABLE-6...308f1e40c6ca28
and I have this router bit set:
http://www.amazon.com/MLCS-8377-15-P...E3E5PH6XDWKWVR
I've been trying all night to get this "round over" bit (1/2" in size) to work with the router but it doesn't seem to "fit" because the router bit "head" won't go into the router base "center" hole. The bit gets tightened in and screwed in fine but when I then put the Router "base" on, the router bit is hanging too low because the router bit won't fit into the router "base" hole (see photos).
Do I just have to go out and buy a smaller sized "round over bit" because this one is too big? I didn't know that routers had a max bit size. If this is the case then I wasted my money on the router bit kit because half of the bits in the kit are the same size (too big).
Am I doing something wrong or is my assumption correct in that the bit is just too big and I have to buy a smaller router bit?
Router bit size too big for router? (Porter Cable 690LR)-img_4093.jpg   Router bit size too big for router? (Porter Cable 690LR)-img_4096.jpg   Router bit size too big for router? (Porter Cable 690LR)-img_4097.jpg   Router bit size too big for router? (Porter Cable 690LR)-img_4098.jpg
HTFreak is offline   Reply With Quote
Old 11-30-2015, 09:06 PM   #2
Rewards Points: 1,742
That's called a 'fixed base' meaning it's not a plunge router, but the position of the motor asssembly in the base should still have some up-down adjustment.
Still it's possible that you have a bit too big for a particular baseplate, it happens often. You can look at making your own baseplate from wood, 1/4" lexan, or buy an alternate baseplate, generic or PC, or take yours off the router and enlarge the center hole.
ChuckF. is offline   Reply With Quote
The Following 2 Users Say Thank You to ChuckF. For This Useful Post:
47_47 (12-01-2015), oh'mike (12-02-2015)
Old 12-01-2015, 08:07 AM   #3
Rewards Points: 144
The baseplates in those PC routers are sized to accept a PC bushing set for doing things like inlay and template work.That is why the recess is there.
As stated above you will need to make or buy an aftermarket baseplate to use your cutters.I have found Lexan to be the best material for this but have made them from 1/4" Baltic birch ply or plexi.
mako1 is offline   Reply With Quote
Old 12-01-2015, 11:21 AM   #4
Rewards Points: 988
something like this is what you need.
http://patwarner.com/selecting_subbase.html
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
1acre (12-02-2015)
Old 12-02-2015, 07:28 AM   #5
Rewards Points: 6,236
Something not right that router comes with 1/4 and 1/2" collets there is no way it should not take a bit that small. A 3/8 roundover is not a big bit. On 690s you remove the motor, install the bit then when you re-install the motor you adjust the height of the bit by twisting the motor.
Entering your general location can help with answering a lot of times
Old 12-02-2015, 08:29 AM   #6
Retired Moderator
Rewards Points: 7,174
Yep---you need to modify the base plate or better yet buy another with a larger diameter opening.
I rarely use the rub collars so most of my PCs have had the holes enlarged.
Old 12-03-2015, 07:10 AM   #7
Rewards Points: 520
Originally Posted by HTFreak View Post
I have this router:
i have 2 pc 690's but with plunge base. and bits like that work fine, get a plunge base for that and it will work , or have the hole enlarged that it will work , should be a quick fix, pc 690's are good routers , have 6 routers and 4 tables not a record but it work's for me good luck
del schisler is offline   Reply With Quote
Cable size to bury for outbuilding subpanel? eholmes77 Electrical 14 11-10-2015 06:50 PM
Porter Cable Compound Miter Saw dust spout broke miamicuse Tools 7 09-06-2015 09:02 AM
Porter Cable FR350 bad driver blade? timp Tools 6 05-20-2009 05:04 PM
Porter Cable Combo kit JFD140 Tools 4 08-11-2007 07:57 PM
Framing Nailer (Porter Cable) Renovator Tools 2 04-26-2006 06:43 PM
