Replacing The Belt On A Crafstman Miter Saw - Tools - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 05-04-2019, 08:08 AM   #1
Rewards Points: 204
replacing the belt on a crafstman miter saw
I finally found a replacement belt for an old Craftsman belt drive miter/shop saw but I don't know how to slip it on.
I don't see an obvious way to loosen one of the spindles.
this model number is: 137.285150 (which apparently is simlar to model 137375640) but I can't find a manual or instructions.
does anyone have experience with a similar saw or can anyone provide insight?
maybe I loosen the motor and that would allow me to tilt the spindle enough to load the belt?
many thanks
Peter
pjstock is offline   Reply With Quote
Old 05-04-2019, 11:50 AM   #2
hkstroud's Avatar
Rewards Points: 5,562
Re: replacing the belt on a crafstman miter saw
Should be able to remove one of the pulleys (probably the one on the blade), put the belt on the pulleys and then put the pulley back on the shaft.
Caution;
The nut on the blade shaft may be a left hand thread.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 05-04-2019, 03:16 PM   #3
retired framer
Rewards Points: 14,572
They are mostly all the same you work them on as you rotate the pulley.
Dave Sal likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 05-05-2019, 06:57 AM   #4
Rewards Points: 430
It also helps to heat up the new belt , just place it on the dash of your car/truck in the sun for about an hour . Makes the new belt more pliable and easier to install .
Porsche986S is offline   Reply With Quote
Gas Dryer won't start with hum, even after replacing motor mactrader Appliances 5 09-17-2018 07:29 AM
FWD Drive Belt Tension vabear Landscaping & Lawn Care 2 11-11-2010 09:40 AM
Belt care... RippySkippy Tools 3 12-25-2008 01:43 PM
Replacing a Snowblower belt Niagarafalls General DIY Discussions 3 12-04-2007 05:53 PM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
