Replacement Blade For Circular Saw? - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 12-16-2016, 07:34 AM   #16
Rewards Points: 625
Re: Replacement blade for circular saw?
Originally Posted by Californiadecks View Post
40 teeth Diablo are rarely needed and have two many teeth for framing lumber. If I am doing a project that requires a 40t blade I'm not going to be using a circular saw. Hardwoods would be cut with my miter saw. Typical 2x material is wet and 24 teeth is your friend! Contrary to what some people believe the more teeth isn't necessarily better. In fact geometry is more important and as dawg was saying, task specific.
As a 31 year carpenter I can count on one hand where I've needed more than 24 teeth, on a circular saw. Too many teeth cause too much heat for most lumber.
Heat is what dulls a carbide blade. Heat breaks down the cobalt that holds the particles of carbide together.
Here's some of the basics, when it comes to blades.
Very helpful, thanks!
For my general purpose cutting needs, how do you feel about the thin kerf on the 24T Dewalts, I linked to earlier?
woodworkbykirk likes this.
a1481155 is offline   Reply With Quote
Old 12-16-2016, 08:15 AM   #17
Rewards Points: 3,240
Originally Posted by a1481155 View Post
Thanks!
Other than general purpose cutting, I have the following projects and/or goals:
1) Repair & replace sections of wooden bench, fencing and gates.
2) Remove & repair section of 3/4 plywood subfloor under 2nd floor toilet.
3) Flooring: install baseboards, scrape adhesive from plywood subfloor, under cut door threshold trim.
4) Refinish oak staircase and rails.
5) Begin to learn basic woodworking/DIY Furniture building i.e. Adirondack chairs, wooden benches, bookcases/shelving, cabinets/doors, etc. FWIW, I'm saving up for a table saw, router and clamps.
I like your plan and the blade you linked in your original post will work just fine for portable saw projects. Save the fine furniture building until you get your tools you're saving for.
For your portable saw use, I recommend building a saw guide(s)to accompany it. I have one each, 4 ft. and 8 ft., for 4x8 sheets and another for cross cutting 2x4s - 2x8s and occasional 2x12 etc. Once you are accustomed to those the speed square will draw dust hanging on the peg board.
http://www.popularmechanics.com/home...a3602/4283497/
a1481155 likes this.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
a1481155 (12-19-2016)
Old 12-17-2016, 09:26 PM   #18
Rewards Points: 102
Originally Posted by Canarywood1 View Post
This blade will do what you want it too.
http://www.homedepot.com/p/Diablo-7-...740R/100017783
I can't say enough good things about Diablo blades. I picked up a bunch for my circular saws when they had a buy one get one free sale a while back. Now I want to get some for my miter and table saws, although they're a bit more expensive for the 10"
Crazyjake8493 is offline   Reply With Quote
Old 12-19-2016, 01:53 PM   #19
Rewards Points: 625
Cool...Now, that said...To me, it seems like a no brainer but without seeing/using the blades, I have to ask...If you were saving for the future, like I am, and had $10, which would you buy?
A) Single Diablo 7-1/4 in. x 24-Teeth Tracking Point Framing Saw Blade
B) The 2-pack Dewalt 7-1/4in Saw Blade (DW3578D2), I linked to in op.
C) This 5-pack Hitachi Circular Saw Blade Set (115402).
Thanks!
I like that idea...Too bad, I just tossed the scraps from an old bathroom cabinet, I just demoed.
Old 01-07-2017, 03:14 PM   #20
Rewards Points: 625
Thanks all!
FWIW, I went with A) Single Diablo 7-1/4 in. x 24-Teeth Tracking Point Framing Saw Blade $9.97
de-nagorg likes this.
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 05:26 PM
Removing a blade from an old Craftsman Circular Saw Davem720 Tools 1 07-05-2010 10:17 PM
IKEA Cabinets and a good saw blade (my experience) DIYatHome Kitchen & Bath Remodeling 0 12-13-2009 08:32 PM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
