Repair Or Replace Table Saw - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Unread Today, 11:31 AM   #16
retired framer
Rewards Points: 23,950
Re: Repair or replace table saw
Originally Posted by SeniorSitizen View Post
The formula is: drive sheave diameter X motor RPM divided by driven sheave diameter.
Example IIR correctly: 1750 RPM X 3" motor sheave divided by arbor sheave diameter of 2" = 2,625 blade RPM.
It is the circumference you play with and your speed would be 3500
Do not use flat bottom gables with scissor trusses.
Unread Today, 11:36 AM   #17
Rewards Points: 2,146
I'd rather play with diameter.
Unread Today, 11:51 AM   #18
retired framer
but the key is 2" is 1/2 the size of a 3"
Unread Today, 02:58 PM   #19
If the above is correct, I'm certain we attended different arithmetic schools.
SPS-1 likes this.
Unread Today, 03:16 PM   #20
retired framer
Yes, not sure what I did wrong but yes. I spent 20 years in an industry where we had to show all the long math, for belt speed. Hopefully my math skills were better then.
The Following User Says Thank You to Nealtw For This Useful Post:
SeniorSitizen (Today)
Unread Today, 04:19 PM   #21
Big Dog
Drachenfire's Avatar
Rewards Points: 4,076
Originally Posted by moosehaed View Post
Not sure if direct drive is the correct term. I was referring to non belt drive saws.
I was looking at something like this or similar.
A basic low price table saw with a stand. https://www.lowes.com/pd/DELTA-ShopM...Saw/1000795558
Sent from my Pixel 2 XL using Tapatalk
That is essentially a circular saw mounted to an inexpensive plastic box with an aluminum table top.
You can get a 1/2 hp motor for under $100 on Amazon.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is online now   Reply With Quote
Unread Today, 04:36 PM   #22
The formula, I originally posted, was for driven RPM if we have both sheave sizes and a known drive RPM.
I had to re-teach myself how to determine what size sheave to attain a certain RPM of the driven if only RPM is known of the drive sheave and diameter. So I went back to pencil / paper and with difficulty re-taught myself how to solve ratio and proportion problems.
To soften the pressure on my deteriorating memory I picked an easy problem I could solve in my head.So in this instance if we want the blade to rotate 3,500 RPM we would need a 1.5" sheave in the saw arbor.
Nealtw likes this.
