Powder Actuated Gun Recommendation - Tools - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 05-17-2019, 10:00 AM   #1
Rewards Points: 44
Powder Actuated gun recommendation
I've got to drive about 100 ITS joist hangers into the top flange of a steel i-beam. Engineer calls out Simpson PDPAT fasteners blasted through the flange. So thats about 200 shots.
So the simpson literature obviously calls out the Simpson PT-27 tool, but I'm wondering if I can use a Hilti or Ramset tools to fire these PDPAT pins? Are they all compatible with one another?
If so, any recommendations? I'm not a professional so I'll likely get something used or not super expensive, but I'd rather buy something because I'm always running into situations where I need a gun.
Rszimm is offline   Reply With Quote
Old 05-17-2019, 12:00 PM   #2
Rewards Points: 866
Re: Powder Actuated gun recommendation
No advice on the gun, but whenever we've had steel I beam in a house it was always a sandwich with wood and we could attach the hangers to the wood part. You might want to check with the engineer to see if that's an acceptable alternative.
NotYerUncleBob2 is offline   Reply With Quote
Old 05-17-2019, 12:08 PM   #3
retired framer
Rewards Points: 14,572
The beam should have been pre drilled for bolts and mounted 1 1/2" lower so you bolt a 2x? on top. Never had to shoot steel.
landfillwizard likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 05-17-2019, 01:11 PM   #4
Rewards Points: 44
The beam is 14" high. The I-Joists are 14" high. There's no room to drop the beam 14"
Old 05-17-2019, 01:32 PM   #5
retired framer
The the beam should have had the web drilled to fill with 2x12 so you could face hang the joists. This was up to the engineer. Now you will nail heads under your sheeting. With wood there you can beat the nails down.
Old 05-17-2019, 04:00 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,138
Ayuh,..... I ran into something like that a few years ago,.....
I welded the brackets on with my mig welder, 'n flux core filler wire,......
Bondo is online now   Reply With Quote
Old 05-17-2019, 05:07 PM   #7
Rewards Points: 44
Around here on-site welding requires a special inspection (i.e. I have to hire an engineer to come watch me weld on 100 hangars). Plus you can't weld the ITS hangars which are so much faster on I-Joists because you don't have to put web stiffeners at the ends. The I-Joists just click in.
Old 06-05-2019, 03:28 PM   #8
HHP123
Rewards Points: 8
A good powder actuated gun is pretty expensive, (in my opinion), and if you don't to expect to use it in the future, it is better to rent one and generally the shots and pins are fairly priced there, too.
HHP123 is offline   Reply With Quote
Powder actuated fasteners into precast concrete? ubelongoutside Building & Construction 20 03-22-2015 03:59 PM
How to remove powder actuated driven nails RickDJ Building & Construction 14 01-12-2014 09:53 PM
Powder Actuated Hammer Tool question? bcdinh Remodeling 10 07-26-2012 09:56 AM
Powder or Liquid Paint Nestor_Kelebay General DIY Discussions 2 01-06-2009 05:05 AM
FS: RamSet "Cobra" Powder Actuated Tool... DIYinTO Tools 2 07-31-2005 02:32 PM
