Porter Cable Portable Table Saw Problem - Tools - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Ranger1227
  • 2 Post By SeniorSitizen
Old 08-11-2018, 10:00 AM   #1
Rewards Points: 247
Porter Cable portable table saw problem
Several years ago I bought a Porter Cable portable table saw for my small workshop. I have not used it heavily. This week I needed to use it to cut some shims for a countertop. The crank to raise the blade would not work. It felt like the gear was stripped but it also would not go past about a quarter turn before locking up. It also would not turn on. I have a feeling something is jammed in there but have not had time to look yet. Any thoughts would be appreciated. Would it pay to get repaired?
Ranger1227 is offline   Reply With Quote
Old 08-11-2018, 10:10 AM   #2
retired framer
Rewards Points: 12,060
Re: Porter Cable portable table saw problem
sounds like you have something jammed in the blade below the table. Turn it over and see what you have.
Old 08-11-2018, 10:20 AM   #3
Rewards Points: 247
I thought of that but have not had time to look at it as I am finishing up the garage project. I will check and Inappreciate the reply.
Nealtw likes this.
Old 08-12-2018, 01:30 PM   #4
Rewards Points: 247
I looked at the saw from the bottom. The gear for the handle to raise the blade is made of plastic and the teeth are sheared off. Not sure why. I hope it is an easy fix. The gear piece is held on the shaft by a set screw
Old 08-12-2018, 01:34 PM   #5
Naildriver
chandler48's Avatar
Rewards Points: 2,084
May find replacement parts at www.ereplacementparts.com
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 08-12-2018, 01:54 PM   #6
retired framer
Can you turn it by some other means or is the motor still stuck in place?
Old 08-12-2018, 01:55 PM   #7
Rewards Points: 247
Blade is below table so not sure if there is a safety that keeps power from turning on
Old 08-12-2018, 01:57 PM   #8
retired framer
You should be able to crank the blade up.
Old 08-12-2018, 02:08 PM   #9
Rewards Points: 247
I did get it to turn on. When I have time this week I will try to find out why crank won’t bufge
Nealtw likes this.
Old 08-13-2018, 08:53 AM   #10
Rewards Points: 3,710
Is there a lock on it.?
Do you have to push the crank in or out to move it.?
ron45 is offline   Reply With Quote
Old 08-16-2018, 07:09 PM   #11
Rewards Points: 247
There is no lock and you do not need to push it in. The teeth on the shaft to which the handle is attached have sheared off. I ordered replacements. I may have to take apart a good bit of the saw and may take it in to fix
Old 08-16-2018, 07:22 PM   #12
Rewards Points: 1,466
Saw dust is the greatest enemy of saw motors, switches and gears. No surprise there. Periodic use of a shop vac and or compressed air are useful cleaning tools too. No surprise there either.
Yodaman and Nealtw like this.
Old 10-18-2018, 05:18 PM   #13
Rewards Points: 247
Thanks chandler48! I ordered the new bevel gears for $10 and was able to replace them myself. the original ones were plastic and the teeth broke off, although I don't know why. The blade now cranks up and down. The Porter Cable service office wanted $200 to do this.
Old 10-19-2018, 06:09 AM   #14
retired painter
Rewards Points: 2,082
As stated above sawdust and debris can hinder the lowering/raising. More than once I've gotten slivers of wood jammed up in mine. Forcing it up/down while it's restricted is probably what wore the gear out. If you have an air compressor I'd blow it out every now and then. The cleaner it stays the better/longer it will operate.
mark sr is offline   Reply With Quote
Porter Cable Compound Miter Saw dust spout broke miamicuse Tools 7 09-06-2015 09:02 AM
How to add a light fixture to a room with a switch controlled split receptacle. pmclough Electrical 12 07-28-2014 09:25 PM
Porter Cable Dovetail Jig - 1/4" shank router bit ryan112ryan Carpentry 4 07-26-2014 08:57 PM
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 10:50 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
