Porter Cable Compound Miter Saw Dust Spout Broke - Tools - DIY Chatroom Home Improvement Forum
Old 08-28-2015, 09:34 PM   #1
Rewards Points: 2,504
Porter Cable Compound Miter Saw dust spout broke
My 12" porter cable miter saw dust spout broke into several pieces.
Model 3802.
In looking up the part number is 1347309.
However, when I search for this I kept running into OBSELETE, NO REPLACEMENT, DISCONTINUED, NO LONGER AVAILABLE...
I really like this saw, it works great and has served me well many years. I would like to keep it and find a replacement dust spout, if possible.
When I typed in "1347309 spout" into search engines, I also found DELTA DUST SPOUT 1347309, does this mean the Porter Cable saw I have was actually made by Delta or they OEM Delta parts? Well in any case the Delta part is also not available.
Any idea where I can find a replacement spout? Looked on eBay also no luck.
Thanks in advance.
miamicuse is offline   Reply With Quote
Old 08-29-2015, 01:37 AM   #2
Rewards Points: 144
I always use ereplacementparts.com but they also show it as unavailable.It should not be to hard to make something that will work.Or build a shroud at the back of the saw with a dust port.
mako1 is offline   Reply With Quote
Old 08-29-2015, 01:06 PM   #3
Rewards Points: 6,236
I have had the factory dust bag on my 12" miter for 5 years and have never emptied it. Does't have enough in it to need emptied yet, about 1/2 full now though
Entering your general location can help with answering a lot of times
Old 08-29-2015, 01:54 PM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
Connect a shop vac to it. It'll actually work a little, unlike the bags which don't work at all.
I hate signatures.
Mort is offline   Reply With Quote
Old 08-29-2015, 07:26 PM   #5
Rewards Points: 1,042
Those things were a joke at the outset, and still are.
Canarywood1 is offline   Reply With Quote
Old 08-30-2015, 06:29 PM   #6
You mean the saw or the dust spout?
Old 09-06-2015, 09:52 AM   #7
In a little over my head
Rewards Points: 710
If you still have the pieces, it might be worth trying to fix it. You can make it stronger than new. Google "Threebond Plastic Repair Kit."
ratherbefishing is offline   Reply With Quote
Old 09-06-2015, 10:02 AM   #8
Mort's Avatar
Rewards Points: 696
The dust bag.
I hate signatures.
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 09:42 AM
Joint Compound Dust Clean Up and Negative Air Pressure System mculton Remodeling 5 03-30-2015 02:58 PM
Porter Cable FR350 bad driver blade? timp Tools 6 05-20-2009 06:04 PM
Porter Cable FR350A Jams With Grip-Rite Fasteners BigJimmy Tools 4 11-11-2007 02:26 PM
Framing Nailer (Porter Cable) Renovator Tools 2 04-26-2006 07:43 PM
