Help What Is This? - Tools - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By CodeMatters
  • 1 Post By lenaitch
  • 2 Post By Nealtw
Old 04-28-2019, 01:42 PM   #1
Help what is this?
Says England n thou...has belt case...
Help what is this?-received_434997533740431_1556476853092.jpeg   Help what is this?-received_278097946407892_1556476866211.jpeg   Help what is this?-received_2065300717102233_1556476874331.jpeg   Help what is this?-received_2314365048779953_1556476890571.jpeg   Help what is this?-received_629855327488025_1556476924613.jpeg
Lstarks7987 is offline   Reply With Quote
Old 04-28-2019, 01:52 PM   #2
Rewards Points: 1,980
Re: Help what is this?
My guess would be some sort of tourge gauge or measuring device. Idk.
jmon is online now   Reply With Quote
Old 04-28-2019, 03:05 PM   #3
Rewards Points: 6,718
Yeah. Seems like it is used to make evenly spaced marks.
SPS-1 is online now   Reply With Quote
Old 04-28-2019, 04:14 PM   #4
CodeMatters's Avatar
Rewards Points: 6,206
Does the little rod move in and out when the dial is turned? If so my guess
would be tire tread depth gauge.
lenaitch likes this.
CodeMatters is online now   Reply With Quote
Old 04-28-2019, 06:05 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,784
Seems a little elaborate (and little wide) but could be. Or something similar. I get the sense that it is very industry specific and mean for quickly checking rather than constructing (it can't be from their auto manufacturing - no British car had anything with that tight a tolerance ). Something like, like railroading or something.
The side with the 'probe' has a lip or edge. Does that probe move in and out as Code asks or does it move around inside its opening? It doesn't appear to be centred. Not much space to move around but it's intended to measure in thousands.
Nealtw likes this.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 04-28-2019, 06:13 PM   #6
retired framer
Rewards Points: 14,806
I was thinking along the same lines , check the diameter of brake drum and maybe the depth of the rivets in old brake shoes.
Do not use flat bottom gables with scissor trusses.
Old 04-28-2019, 08:09 PM   #7
Usually Confused
lenaitch's Avatar
On further thought, the 'probe' looks quite rounded and not consistent with micro measurement for a lateral direction, but then again the pic is a bit blurry.
Nealtw likes this.
Who Dares Wins
Old 04-28-2019, 08:23 PM   #8
retired framer
Well it is not a tool used all day or the holster would be open on top but it needs to be handy for who ever uses it, so it is some kind of inspection aid. I think.
lenaitch and CodeMatters like this.
