Hedge Trimmers Opinions - Tools - DIY Chatroom Home Improvement Forum
Like Tree12Likes
Old 04-07-2019, 08:05 PM   #1
Rewards Points: 706
Hedge Trimmers opinions
I didn’t understand the teeth size when I bought my B & D corded trimmer. Its ok for small thin shrubs for a light trim.
Now we’re looking at heavy duty trimmers for bigger shrubs. Do you recommend a corded or battery for a big trimmer?
Things to be trimmed are big Azealas, hibiscus, Cape Honeysuckle, Viburnum, golden dewdrop, big gardenias an more.
Startingover is offline   Reply With Quote
Old 04-07-2019, 08:12 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,570
Re: Hedge Trimmers opinions
The batteries are so good these days that its tough to recommend anything else for homeowner use. Most of your commercial guys will run 2-stroke trimmers, but for a homeowner, you can't go wrong with battery. So easy, bit more expensive, but much more user friendly.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Startingover (04-07-2019)
Old 04-07-2019, 09:36 PM   #3
Rewards Points: 706
Which brand preference?
Old 04-07-2019, 10:07 PM   #4
Rewards Points: 309
When my B&D corded weed whacker started to go bad I decided to replace both it and the hedge trimmer with battery powered units. It was a tough call. But the thing with the string trimmer was I wanted to go cordless one way or another. But the idea of yet another 2 cycle engine wandering around the garage bothered me. Another engine to maintain, another spark plug and filter to manage, more gas to drain each season, etc.
My main concern was the power. I'd seen others/neighbors with these underpowered things. But after a lot of research I decided to bit the bullet on DeWalt 40V series. They also have a 60V collection, but that seemed overkill and more commercial. So, for the hedge trimmer I ended up with this:
Dewalt DCHT860M1R 40V MAX 4.0 Ah Cordless Lithium-Ion 22 in. Hedge Trimmer
I got mine as a refurb to save a few bucks since it came with full warranty, etc. This thing - just like the string trimmer - is more powerful than the corded units I'd had. No stupid cords to unwind and wind up. And no engine to maintain. Or gas to buy. Given the cost of this is about the same as something with gas, (maybe a bit more or less), and over time you save money on gas, this was - I think - the best home DIY tool choice I've made in awhile. It works great. I can't tell you exactly what diameter branches it can cut. All I can say is for maybe 20 linear feet of typical hedges and dozens more feel of various typical suburban home bushes of various sizes, there's zero issue chopping up whatever.
It's usually much cheaper to acquire batteries when you buy a tool. So I did get both units with the kit/battery. Now I've got a charger mounted on wall in garage and one in workshop. In both cases, I use a countdown timer on the chargers' wall plugs. So when I charge a battery, I set it for a few hours and that's that. I know these things are supposed to have circuitry to avoid overcharging, etc. But whatever. With the timer, all the power gets cut off so I don't have to worry about wasted power or any battery issues.
Other brands of similar status as DeWalt can probably get it done with their Commercial or "Prosumer" level gear. I'd avoid cheapie "house brand" type solutions perhaps. Bottom line is the battery tech in these things is finally the real deal for getting things done. The fact that commercial ops are even moving to these things more and more - and not for just regulatory reasons - pretty much tells us that.
ChuckTin likes this.
Scottg is offline   Reply With Quote
The Following User Says Thank You to Scottg For This Useful Post:
Startingover (04-08-2019)
Old 04-08-2019, 08:59 AM   #5
Rewards Points: 17,830
There is no "tooth" size on a trimmer that I've ever heard of.
If the limbs are to big to cut with a trimmer, use a lopper.
Startingover and Colbyt like this.
Old 04-08-2019, 10:10 AM   #6
Rewards Points: 706
I definitely can’t deal with gas an know my daughter wouldn’t.
Joe, i guess it was was branch diameter that was listed an not tooth size. Not sure what a lopper is but will look it up. I still love my Sawzall you recommended about 6 yrs ago.
We’ll go look at Dewalt. Thanks
Old 04-08-2019, 12:00 PM   #7
Rewards Points: 952
I've been using this one for a while now , and it cuts pretty much anything i have including oleander.
https://www.homedepot.com/p/RYOBI-ON...2660/206451795
Canarywood1 is offline   Reply With Quote
Old 04-08-2019, 12:22 PM   #8
ZTMAN's Avatar
Rewards Points: 254
Shindaiwa has a close out on their 56v cordless hedge trimmer. You cannot beat the price:
https://www.stringtrimmersdirect.com...er/p93216.html
I order them, and they work great. These are large trimmers and need two hands to operate because of the safety features.
I have a corded 20' set and a gas trimmer that attaches to my string trimmer. They all have their own particular job, but I really like the battery operated trimmers.
Startingover likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 04-08-2019, 12:50 PM   #9
HDS
Rewards Points: 292
I have the Milwaukee M18 battery powered hedge trimmer and it does quite well. Only drawback is it can get a tad heavy after a lot of use, but not that bad. Also have the blower and it works really well too. I did keep my corded for really big jobs as I only have one battery, but will probably ditch it once I add more. Also looking to get the string trimmer just so I don't have to deal with anymore mixed fuel.
HDS is offline   Reply With Quote
Old 04-08-2019, 12:59 PM   #10
Rewards Points: 706
we need to see them in person to see how heavy they are. My forearm gets sore just using my Toro battery weed trimmer.
Old 04-08-2019, 07:38 PM   #11
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
I also have the Milwaukee M18 (which I won from this site, full disclosure), and it’s great. I also have the blower and string trimmer which are also very good. My only complaint was with the string trimmer, it doesn’t break down in half, but they’ve since redesigned it so it does. Wouldn’t normally be an issue but I tried to get it into the trunk of my BMW one time and it wouldn’t fit.
I hate signatures.
Mort is offline   Reply With Quote
Old 04-09-2019, 07:03 AM   #12
landfillwizard's Avatar
Rewards Points: 612
I have an 18 volt Ryobi trimmer. I also have have about 30 other 18 volt Ryobi tools so I have many batteries to keep it going. I Have ~40' if hedges to trim and also use it to trim my raspberry bushes. Just before I use it, I spray the sickle bar with Blaster to lubricate the blade. I have had the tool for 5 years and have had no problems!
landfillwizard is offline   Reply With Quote
Old 04-09-2019, 10:35 AM   #13
Rewards Points: 706
Never thought to lubricate blades. Thanks
Old 04-09-2019, 10:48 AM   #14
Rewards Points: 6,671
There are two very different styles of loping shears, anvil and by-pass.
IMO and it may just me the anvil style works best for 3/8 - 3/4" branches and the bypass works better for 3/4 - 1-1/4.
Any decent quality, lubricated hedge trimmer should handle green stuff up to 3/8.
Most folks will probably only buy one and use the sawsall for the large stuff.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 04-09-2019, 01:48 PM   #15
Rewards Points: 952
I always spray mine after i finish, so they will be ready to go when i start , i also like the blade tilt feature on the Ryobi
Mixed hedge bluefoxicy Landscaping & Lawn Care 0 06-11-2014 06:10 PM
stihl hs46 hedge trimmers funkjosh Landscaping & Lawn Care 4 05-26-2012 02:21 PM
hedge trimmers and lawn edgers ? Fix'n it Landscaping & Lawn Care 8 05-14-2012 09:35 PM
string trimmers: what do the pro's use? av-geek Landscaping & Lawn Care 6 04-30-2012 10:09 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
