Hammer Drill Vs. SDS/SDS+ Vs. SDS-Max - Tools - DIY Chatroom Home Improvement Forum
Old 05-03-2019, 10:33 AM   #1
Rewards Points: 558
Hammer Drill vs. SDS/SDS+ vs. SDS-Max
Recently used a 1/2" HF hammer drill with a 2" diamond hole saw through some decorative granite stone on an exterior wall. It was pretty slow and seemed a little underpowered for the job. It's not too bad drilling a couple of 3/8" holes a couple inches deep for concrete anchors. However, I have a few more holes through this decorative granite stone as well as a few hole through brick siding too. Max hole size would be 2.5" - 3".
Considering purchasing a new drill, but I'm at a loss of which is best "multi-function" tool and what work each is best suited for. Thoughts?
In other words, for 1" and under holes for anchoring with the occasional 2"-3" hole saw for plumbing pipes through masonry exterior surfaces, am I better off sticking to a hammer drill, or look to bigger SDS rotary hammers? Ideally I'd like an SDS-max rotary hammer with drill only, hammer only, and drill + hammer, but it doesn't look like these exist.
Hammer drill:
-Standard chuck
-Works alright for light duty concrete/masonry hammering
-Works, but slow for diamond hole saw drilling. Not sure if this is normal diamond hole saw behavior, or an issue of drill power.
SDS/SDS+:
-SDS/SDS+ chuck
-Would need a SDS to standard chuck adapter to use hole saws found at local big box store
-A bit more power and has ability for light demo work (tile chipping, very small concrete areas)
-Can find models with 3 modes - drilling, hammer, drill + hammer
SDS-Max:
-SDS-Max chuck
-Would need SDS-Max to SDS/SDS+ adapter since local stores mainly carry SDS/SDS+ bits
-More powerful and capable of slightly heavier demo work (ex. could slowly break up basement concrete for bathroom plumbing, but not the best tool for the job)
-Models only have 2 modes - hammer only and drill + hammer
-This means you wouldn't be able to use diamond hole saws with standard chuck and would be looking at expensive SDS core bits for holes
dtbingle is offline   Reply With Quote
Old 05-03-2019, 01:07 PM   #2
Rewards Points: 982
Re: Hammer Drill vs. SDS/SDS+ vs. SDS-Max
SDS/SDS+ is the way to go. Hammer drills don't really have much "oomph" for this kind of work.
I'd also suggest getting the right bits for them or renting the whole setup if you can (and won't have a regular need for it later).
If you shop around you can get a decent Milwaukee SDS+ reconditioned for fairly cheap ($115 right now or $99 for a recon Bosch). Take a look at www.CPOoutlets.com
Don't bother with Horror Fright...they're straight up junk and a waste of money IMO.
NotYerUncleBob2 is offline   Reply With Quote
Old 05-03-2019, 02:55 PM   #3
Rewards Points: 558
Makes sense.
So basically SDS/SDS+ is pretty good for most stuff around the house as far as light tile chipping, masonry drilling & coring. And you definitely suggest getting the SDS core bits vs. the standard shank diamond hole saw?
Then SDS-Max is mainly for the odd large & uncommon holes for a homeowner and would be better off renting for those infrequent uses. And anything concrete demo related should look to renting a demo hammer, jackhammer, etc based on size of project?
Old 05-03-2019, 03:11 PM   #4
Rewards Points: 4,330
Harbor Freight can be a good place to purchase tools but you're generally going to get homeowner level and not contractor level, meaning they won't be suited for use every day or may lack the power of the pro tool - this would be one case where HF might lack the power but then again, they might not.
stick\shift is offline   Reply With Quote
Old 05-30-2019, 12:15 PM   #5
Rewards Points: 36
Good info. I grabbed a BlackÚDecker on amazon for about $40...the cost of renting for one day at the store... Drilled about 30 holes in cement walls for shelves... The bosch drill bit still going strong...amazing that company.
duanef is offline   Reply With Quote
Old 06-01-2019, 11:18 PM   #6
Usually, you wouldn't use a hammer drill for granite. All the countertop top shops just use a grinder with the bit attached. Too much of a risk for the granite to break with a hammer drill. For the brick we usually use sds or sds max.
paul100 is offline   Reply With Quote
Old 06-01-2019, 11:25 PM   #7
Concrete & Masonry
Rewards Points: 422
Never seen this until yesterday, actually. The HVAC guys came to drill a number of AC line sets through the brick wall with a 2" diamond core on a 7"grinder. Without a centering bit, it took a little to get started, but once started, I couldn't believe how they bored through the wall in seconds.......
jomama45 is offline   Reply With Quote
Old 06-01-2019, 11:32 PM   #8
Rewards Points: 1,290
A hammer drill is the wrong tool to use with an abrasive diamond hole saw.
Anti-wingnut is offline   Reply With Quote
Old 06-02-2019, 08:30 PM   #9
Rewards Points: 982
IMO Horror Fright power tools are junk. period. Yeah, maybe it'll last a day, but the frustration is just not worth it. Anyone who says that HF is ok hasn't used a real tool for that job before.
If you want to save a few bucks, just buy a used good tool off craigslist or a factory reconditioned one off CPOoutlets.com
Old 06-25-2019, 03:51 PM   #10
Rewards Points: 788
SDS Plus is the best addition to your hammer drill. You can find bits up to 1-3/8 for concrete and also wood arbor bits with a SDS shank.
For most stone a tungsten carbide bit will work fine. Problem with brick is that there are multiple types including the exterior brick veneer that is often fire hardened and on par with ceramics in terms of its hardness. For brick a diamond cutter is best.
Hammer action will speed up drilling but you do risk cracking the material. These are also underpowered as compared to a core drill that is engineered to use with core bits and have more power and lower gearing as well as a way to feed water into the core bit to remove the cuttings.
For anything that requires the use of a SDS Max drill I would rent it by the day as even with large projects I have yet to need one. For holes 1.5" and larger I use my core drill and a core bit.
For brick a dry cutting core bit works fine if it has laser welded diamond cutting segment. If the core bit manufacturer or dealer mentions free segment replacement it means that the segments were brazed on and best to steer clear of them.
Dry cutting core bits have a 5/8-13 thread mount and so can be used with an adapter or with an angle grinder as these have this threading as well.
Calson is offline   Reply With Quote
The Following User Says Thank You to Calson For This Useful Post:
dtbingle (07-30-2019)
Old 10-09-2019, 01:27 AM   #11
Rewards Points: 2
Don't waste your time with hammer drills. Go with an SDS Max if you want to drill large diameter (Over 1") relatively quickly. (I have an SDS max and plus) The SDS Max rotary hammers will cost a bit but get a quality one like Bosch. It'll probably set you back $400+. You can get an SDS plus bosch for about 150
I've been using this set of bits I originally got at amazon manufacturer is kateya its a seven piece set. I highly recommend.
Oh and don't use an adapter for sds plus bits with a max hammer you'll break your bits
gmocharger is offline   Reply With Quote
shopping for rotary hammer drill question Pawl Tools 5 09-16-2014 06:28 PM
Report: Hitachi Brushless Hammer Drill & Impact Driver Combo More Power! Tools 0 07-27-2014 10:28 AM
My new rotary hammer drill wobbles. rick112 General DIY Discussions 8 04-13-2011 10:34 PM
rotary hammer drill ctkeebler Tools 8 04-10-2010 10:42 PM
Hammer drill spits sparks Termite Tools 2 03-16-2010 03:29 PM
