Hammer Drill & Mud Mixer - Tools - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By jlhaslip
  • 2 Post By de-nagorg
  • 3 Post By XSleeper
Old 01-07-2018, 05:59 PM   #1
Rewards Points: 2,362
Sorry for the long post.
My regular corded hammer drill, a Makita HP1501K which I owned for over two decades, is failing. The chuck is no longer protruding and retracting as I tighten and loosen, and has gotten worse over the last two months. During hurricane Irma a few months ago I was drilling a lot of concrete blocks (had to attach about 40 sheets of 4X8 plywood with 10-12 Tapcon screws per sheet) in the rain and I think some water and concrete dust got into it, and recently I was drilling upward with a paddle bit into cement based plaster on the ceiling, and a lot of the debris fell into it. Anyways I got 20 years out of it so I am looking for a new hammer drill.
Now, I do have a Ridgid brand 18V cordless hammer drill as part of a Ridgid combo kit I bought last year. A Gen5 BRUSHED hammer drill and compact driver combo. Tried to use the hammer drill - and I don't really use a hammer drill for anything else besides drilling holes for Tapcon 80% of the time, and the other 20% is using it for hole saws, whether it's wood holes for plumbing electrical through wood studs, or carbide/diamond hole saws on tiles. I have tried the Ridgid cordless hammer drill, and it just doesn't perform as fast as the corded Makita. So I use the cordless only when an extension cord is really inconvenient. Was kind of disappointed the cordless hammer drill couldn't retire my corded one.
I also have a Bosch SDS rotary hammer for heavy duty drilling and chipping. It's too heavy to use for lighter duty tasks.
So it looks like I need to get a new hammer drill.
At the same time, I have a few cement/plaster projects coming up. I will need to mix some stucco for windows, some veneer plaster for ceilings, some concrete mix for paver edges and fence posts. So I could use a mud mixer because I know a traditional drill can't handle mixing mud in a 5 gallon bucket.
So what I want to know is, is there a new corded hammer drill out there, that is capable of doing both hammer drilling AND mud mixing? Or do I need to buy TWO tools?
Alternatively, could I use my SDS rotary hammer to mix mud and not buy a dedicated mud mixer?
Finally, is my disappointment in the cordless hammer drill a result of the brand & model I selected - Ridgid? Are there other brands out there whose hammer drill can come close to the performance of a corded one?
Apologize for the convoluted and messy post.
miamicuse is offline   Reply With Quote
Old 01-07-2018, 06:16 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 2,330
Re: Hammer Drill & Mud Mixer
Why are you stuck on a "hammer" drill? They aren't made for mixing slurry. If you are going to do a bunch of it, go ahead and buy an angle 1/2" drill. I use a Ridgid, but Hole Hawg is another brand. Much easier to use since it is parallel to the ground while you are mixing. And forget battery powered.
https://www.homedepot.com/p/Milwauke...75-6/100000548
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-07-2018, 06:38 PM   #3
jlhaslip's Avatar
Rewards Points: 708
I would never be able to lift the battery tool version of the standard 1/2 mud mixing drill.
The battery would start a D8.
Go with corded for the mud mixer.
mark sr likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-07-2018, 06:41 PM   #4
I am not saying I would use a hammer drill for mixing mud. I apologize if my initial post was not clear.
I am saying I am in the market for a new hammer drill because the old one has died.
I am also in the market for a mud mixer because I have a few tasks up ahead that needed one.
My question is, is there a tool out there in this day and age that allows you to do both?
I am always looking to reduce the number of tools I have. So I wonder if my Bosch SDS xtreme viper who I only use to do some occasionally chipping and drilling could possibly mix mud.
I have used my old Makita hammer drill to mix stucco and joint compound in the past - but those were small loads and no aggregates to spin around.
Old 01-07-2018, 06:46 PM   #5
Naildriver
chandler48's Avatar
Nooooo !! Say it ain't so. With the SDS, you have a hammer drill, so you may want to concentrate on an electric drill in 1/2" to do your mixing.
Larry......
Old 01-07-2018, 08:20 PM   #6
Yes, less number of tools the better LOL. I have probably more tools sitting in boxes that I have used once or twice then I put them aside forever.
I use the SDS rotary hammer only to break through concrete block walls for pipes and vents, or to drill larger holes in slabs. That's a few times a year occurrence.
But I drill Tapcon screw holes a lot more. So I use a smaller hammer drill for that. I cannot imagine standing on an 8' ladder, trying to mount plywood shutters as the hurricane approaches, doing 8-10 holes per window, with 30, 40, 50 windows to cover and using a larger heavier rotary hammer and still keep balanced, even with two people one drilling one holding up the boards it's rather tough.
It's for the same reason I thought a cordless one which is lighter and no cords to drag around would be easier, well that was a mistake, so now that cordless hammer drill sits somewhere.
So it seems like I need to get a new hammer drill, and a new mud mixer.
Old 01-07-2018, 08:42 PM   #7
JUSTA MEMBER
Rewards Points: 2,398
I am confused, you stated that the chuck was acting up on the Makita, then later you state that it has died.
Either way it is repairable, there are replacement chucks available, there are also new brushes and a little shaft grease available for the motor.
So does it still motor well, just a tired old chuck, or has the motor really died.
either way don't throw it away, send it to me, and I'll repair it and have me a reliable old school tool.
I'll even pay the freight charges.
ED
Bondo and mark sr like this.
de-nagorg is offline   Reply With Quote
Old 01-07-2018, 08:59 PM   #8
Rewards Points: 1,265
Plus if the chuck has froze, it is likely frozen from rust... since you said it got wet. PB Blaster and a few taps with a hammer would surely free it up again. Those who can't buy new tools all the time have to maintain them.
Bondo, de-nagorg and mark sr like this.
XSleeper is offline   Reply With Quote
Old 01-08-2018, 12:43 AM   #9
Rewards Points: 4,700
I have a much older battery powered Rigid drill, but light it isn't. But it has a hammer setting on the chuck as opposed to being a dedicated hammer drill. May not be the best but I have drilled hundreds of holes in concrete. Just recently had to dig it out and charge up those pesky batteries (another story) but it performed perfectly.
Now, it has pretty good power, but even on the drill setting I wouldn't use it to mix the mud you describe. Definitely think a 2 tool solution here is much better.
On another note, I love my 18v Makita hammer drill but it has the quick connect that uses the detente which doesn't work with my collection of masonry bits. So, I picked up a universal shank keyless chuck made by Makita. I haven't tried it yet to see if it is as good as the old Rigid.
Bud
Bud9051 is online now   Reply With Quote
Report: Hitachi Brushless Hammer Drill & Impact Driver Combo More Power! Tools 0 07-27-2014 09:28 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 09:42 PM
Hammer drill spits sparks Termite Tools 2 03-16-2010 02:29 PM
