Chainsaw Stalling At Full Throttle - Tools - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By CodeMatters
  • 1 Post By tripower
  • 1 Post By m_ridzon
Old 07-05-2019, 04:06 PM   #1
Rewards Points: 356
Question
Chainsaw stalling at full throttle
I have a Husqvarna 455 rancher. I just replaced the carb. On cold start the saw goes up to full throttle just fine. Upon warm-up the chainsaw does not allow me to go to full throttle which is proper cutting speed. Any ideas on what could be going on?
tripower is offline   Reply With Quote
Old 07-05-2019, 04:56 PM   #2
JUSTA MEMBER
Rewards Points: 1,028
Re: Chainsaw stalling at full throttle
Restricted air flow, or fuel flow.
Inspection is warranted.
ED
de-nagorg is online now   Reply With Quote
Old 07-05-2019, 05:24 PM   #3
Oso954's Avatar
Rewards Points: 642
Did you adjust the carburetor ?
Husqvarna ships their new saws with limited rpm for break in. They recommend that you have a tech adjust the carb after 10 tanks of gas.
IDK, but they may ship the replacement carbs with the same adjustment as the new saws.
If you want to try adjusting it yourself, there are a set of instructions here.
https://www.hunker.com/12384628/how-...rna-carburetor
Oso954 is offline   Reply With Quote
Old 07-05-2019, 06:48 PM   #4
CodeMatters's Avatar
Rewards Points: 7,346
ED
Gee, do ya think? lol
Nealtw likes this.
CodeMatters is online now   Reply With Quote
Old 07-05-2019, 09:10 PM   #5
Rewards Points: 356
my thoughts exactly.
CodeMatters likes this.
Old 07-05-2019, 09:11 PM   #6
Rewards Points: 356
The carb was aftermarket. i think I am sending it back it is not very well made IMHO.
Old 07-05-2019, 11:02 PM   #7
JUSTA MEMBER
Often aftermarket stuff is a junk copy of the REAL thing.
You might be wise to return it ( if they accept it), and get an OEM unit.
I realize that the price will be enormous, but if it works right, worth the cost.
And good luck with your saw.
ED
Old 07-06-2019, 10:07 AM   #8
Rewards Points: 356
ED
Your insight is just stunning....
Old 07-06-2019, 12:56 PM   #9
Usually Confused
lenaitch's Avatar
Rewards Points: 684
Check the muffler screen. They can get clogged with carbon and prevent the engine from breathing.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 07-06-2019, 04:37 PM   #10
Rewards Points: 4,988
Try adjusting the choke and see if that helps.
ron45 is offline   Reply With Quote
Old 07-10-2019, 08:55 AM   #11
Too Much DIY!
Rewards Points: 554
Virtually any small engine I have worked on (weed eater, chainsaw, hedge trimmer, etc.) needs a hi-speed jet adjustment on the carb when this behavior occurs.
Just my $0.02.
de-nagorg likes this.
m_ridzon is offline   Reply With Quote
