Bind-Up Control: Dewalt DWD460K - Advice - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 04-06-2019, 08:02 AM   #16
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,940
Re: Bind-Up Control: Dewalt DWD460K - Advice
Originally Posted by chandler48 View Post
I don't think I would use any battery powered drill with an auger bit. Too much drag. If I were doing a bunch of holes, I would be using something like a Hole Hawg, or similar right angle 1/2" drill. Just hold on for the ride
Ayuh,.... My monster Milwaukee right-angle hole hawg has 3/4" pipe threaded holes in it for the extra handle(s),.....
Screwin' longer lengths of pipe into 'em will give ya the leverage to hang onto it,.....
'course, that'll also turn it into a 2 or 3 man operation,.....
Yodaman likes this.
Old 04-06-2019, 09:22 AM   #17
Big Dog
Drachenfire's Avatar
Rewards Points: 4,308
I suggest you start with a smaller diameter bit and use a slower speed. Also pull the bit frequently to clear chips as others here have suggested.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 04-10-2019, 07:36 PM   #18
Rewards Points: 906
Drag is from surface contact area. A hole saw has constant contact with both the inner side and the outside. Take a brand new bi-metal hole saw and cut a hole in 3/4 plywood or a DF 2x4 and look at the burn marks on the side of the hole saw. A TCT cutter with its large teeth has not side wall contact inside or outside while the material is being cut, so the drill only needs to provide power to have the teeth cut the material.
Same deal with an auger bit that was designed for wood timbers and low speeds as compared to modern spiral type bit that has only the cutting edges touching the material and plenty of space to remove the cuttings and keep them from adding resistance. This is important and it is why when cutting concrete with a core drill bit a stream of water is added to wash away the cuttings so the drill bit does not bind.
Unfortunately people insist on using the same drill bits and hole cutters that their grandfathers used and small wonder that they have problems with cordless drills or with engineered materials.
Calson is offline   Reply With Quote
Building a Master Control Panel gashalot Electrical 12 03-10-2013 08:38 AM
Circuit advice needed for a Remote Control Door Lock plppianoman Electrical 0 12-27-2012 01:13 PM
flow control valves jmon HVAC 9 12-12-2012 11:53 AM
NEED ADVICE: Moved into new apt, ceiling vibrating out of control! AtWitsEnd Flooring 1 10-29-2011 03:14 AM
Need quick advice for erosion control desperatebyard Landscaping & Lawn Care 2 12-03-2010 03:35 PM
