Best Tool For Cutting Plastic Shower Surround - Tools - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 3 Post By RRH
  • 2 Post By hkstroud
  • 1 Post By ron45
  • 1 Post By Dave Sal
  • 1 Post By MTN REMODEL LLC
  • 1 Post By Calson
Old 03-09-2019, 11:00 AM   #1
Rewards Points: 40
Best Tool for Cutting Plastic Shower Surround
I need to replace the mixer cap and pressure balancing unit for my shower handle, but the opening cut into the plastic shower surround isn't large enough to get this done. Looking for recommendations on the best approach to increasing the opening size without sending shards of plastics everywhere.
slowmotion is offline   Reply With Quote
Old 03-09-2019, 11:09 AM   #2
RRH
Rewards Points: 1,196
Re: Best Tool for Cutting Plastic Shower Surround
I myself would just take my mutimaster with a narrow blade.
If you have plenty of time and not the right tools. Then draw the line and make a bunch of small holes with a drill. break off with pliers.
Will be covered by trim piece so does not need to look pretty.
RRH is offline   Reply With Quote
The Following User Says Thank You to RRH For This Useful Post:
slowmotion (03-10-2019)
Old 03-09-2019, 01:01 PM   #3
hkstroud's Avatar
Rewards Points: 5,322
I think I would use my compass in the screw hole of the stem to draw a circle. Then use my oscillating multi function tool to cut it out.
landfillwizard and slowmotion like this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Old 03-10-2019, 11:36 AM   #4
Rewards Points: 3,710
https://www.usplastic.com/catalog/it...yABEgK6tvD_BwE
Don't cry..
https://www.northerntool.com/shop/to...SABEgIXVfD_BwE
Windows on Wash likes this.
ron45 is offline   Reply With Quote
Old 03-12-2019, 02:33 PM   #5
Dave Sal's Avatar
Rewards Points: 722
Would it be easier on the other side of the wall? Maybe there's drywall that you can remove and easily patch when you're done.
Gymschu likes this.
Dave Sal is online now   Reply With Quote
Old 03-14-2019, 10:24 AM   #6
landfillwizard's Avatar
Rewards Points: 606
If you don't have a multittool, I would get the tool form HF. I bought one 10 years ago for one project because it was inexpensive. Now it is one of my most used tools for projects like what you have. After I use it, I blow it off with an air gun.
landfillwizard is offline   Reply With Quote
Old 03-14-2019, 11:23 AM   #7
Property Mgt/Maint
Rewards Points: 6,080
A trim router or Roto-ZIp would also work, but I would grab the multi tool first. It will not make a perfectly round hole but will be the safest and least likely to damage anything.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 03-14-2019, 11:32 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,556
^^^^^^^^^^^^^^^^^LANDFILL^^^^^^^^^^^^^^^^^^^^
Not sure, or can't remember, how we existed for 40 years without the oscillating tool. And , they are basically inexpensve.
Yodaman likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 04-03-2019, 01:54 PM   #9
Rewards Points: 272
Another option is to cut the new hole size first in a piece of 1/2" wood and have someone hold it in place so you can cut the new hole with the pilot bit removed from the arbor adapter. With plastics the cheapest bi-metal hole saw will do the job and if concerned about chipping you can run the drill in reverse so the backs of the teeth are hitting the plastic.
Domo likes this.
Calson is offline   Reply With Quote
Painting Kitchen Cabinets mkretsinger Painting 5 11-07-2015 12:54 PM
Replace wall above shower surround wsiegferth Drywall & Plaster 2 07-23-2015 11:43 PM
What's behind that plastic tile in the shower? Do I really *want* to know? El Barbón Remodeling 20 12-23-2013 10:38 PM
Plastic shower base and concrete / leveling issue JoTeeBee Kitchen & Bath Remodeling 2 06-17-2011 07:46 PM
Re-doing a shower surround belizeanbus Kitchen & Bath Remodeling 9 04-18-2010 11:57 AM
