Air In Gun When Clear Jammed Nail In Pneumatic Air Framing Gun Nailer? 1 Shot Safety? - Tools - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By jlhaslip
  • 1 Post By woodworkbykirk
Old 02-17-2017, 05:33 PM   #1
Rewards Points: 192
Air in gun when clear jammed nail in pneumatic air framing gun nailer? 1 shot safety?
suppose I get a nail jam in a pneumatic gun. If I disconnect the air hose, is there still air in the gun (or any other pneumatic tool like a grinding wheel etc)? If there is still air in it, is there a way to bleed it out without attempting to shoot the gun with a nail jammed in there?
also, suppose I have the gun on single shot mode, if I hold the trigger and then push the nose down, will it shoot, or it would only shoot in bump/rapid mode if that's done?
gunner66 is offline   Reply With Quote
Old 02-17-2017, 05:55 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Air in gun when clear jammed nail in pneumatic air framing gun nailer? 1 shot saf
By Law (or OHSA Regulation?), the air should drain from the gun when the air hose is disconnected, otherwise the potential for injury is there. Makes sure the gun has the open MALE end on it and you will be fine.
Single shot mode "should" not allow for a bump fire. If it does, and I suggest you check every so often, the trigger is broken and needs to be taken out of service until repaired. Only rapid fire mode should allow a bump fire.
Single fire mode requires the nose switch to be depressed prior to the trigger or else it is broken.
*edit*
And ALWAYS disconnect the air supply before attempting to clear a jammed gun.
landfillwizard likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-18-2017, 07:45 AM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
the tool has back pressure on it within the line going up through the handle.... pulling the trigger opens a valve which lets the air into the nailer head / motor..... as soon as you disconnect the hose the air will come back out though the male fitting thats that hiss / pop sound when you disconnect
Californiadecks likes this.
woodworkbykirk is offline   Reply With Quote
Old 03-09-2017, 06:39 PM   #4
Rewards Points: 1,066
Originally Posted by gunner66 View Post
If I disconnect the air hose, is there still air in the gun?
Nope.
NotyeruncleBob is offline   Reply With Quote
help with my jammed framing nailer gbwillner Tools 13 01-11-2014 12:07 PM
Pneumatic air gun misfires on first shot, screws up on the second chung21 Tools 4 02-10-2009 08:58 AM
Porter Cable Framing Nailer Problem rutilio Carpentry 9 08-07-2008 08:23 AM
