24 V Black & Decker Circular Saw BDCS2406 - Tools - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By SeniorSitizen
  • 1 Post By carpdad
Old 12-30-2019, 03:24 PM   #1
Need help changing out the blade my blade clamp screw that holds the blade onto the saw is stripped out how would I go about removing it so that it and the blade both may be replaced
Jmccauley050809 is offline   Reply With Quote
Old 12-30-2019, 04:12 PM   #2
Rewards Points: 3,660
Re: 24 V Black & Decker Circular Saw BDCS2406
Send the saw to a service center.
https://www.service-center-locator.c...ice-center.htm
Old 12-30-2019, 06:21 PM   #3
Rewards Points: 8,142
Trying to determine the direction to turn to remove that nut but search was not helpful. Are you certain which way to turn to remove?
My Battery powered Rigid is a left hand thread.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 12-30-2019, 06:50 PM   #4
Bud
To tighten, the screw turns opposite the rotation of the blade.
https://www.naturalhandyman.com/qa/qatoolmisc.html
Bud9051 likes this.
Old 12-30-2019, 07:01 PM   #5
I've always followed, if blade is on the right it is a right hand screw. If on the left it's a left hand screw. Seems like some genius would have come up with a way to mark all LH nuts and bolts, but never saw anything.
Bud
Old 12-30-2019, 07:07 PM   #6
Some have an arrow on the guard for rotation direction but it seems they never learned the alffabet.
Old 12-31-2019, 04:12 AM   #7
Rewards Points: 554
The shaft may be part of the motor, so repair may be more cost than buying a new saw. Since battery, does b&d sell tool only? Check youtube video AVE. See if he did any tear down on a saw? Check other videos on circular saw repairs. See how involved or simple it is and it should give you some idea what the cost may be. Videos don't have to be b&d. They are similar. Twins may be craftsman and maybe dewalt.
SeniorSitizen likes this.
carpdad is offline   Reply With Quote
Old 12-31-2019, 08:22 AM   #8
That's why I mentioned service center. I've not owned very many but I can only recall those having a cap screw holding the blade on. Unless the saw would be conducive to being fitted with a helicoil and the OP is capable of installing one, it either goes in the dumpster or to a service center for repair or replacement.
Old 01-14-2020, 06:07 PM   #9
Rewards Points: 1,084
I would find someone with an arc welder to weld a piece of bar stock to the head of the screw. These are usually left hand screws so you turn them clockwise to loosen them.
Calson is offline   Reply With Quote
