Why Are Crawl Space Dehumidifiers So Expensive? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-16-2018, 08:31 AM   #1
Rewards Points: 166
Why are crawl space dehumidifiers so expensive?
I am looking at controlling moisture in a crawlspace and find a big difference in price between room dehumidifier and crawlspace dehumidifiers. Wondering why?
comfun1 is offline   Reply With Quote
Old 11-16-2018, 10:13 AM   #2
Rewards Points: 8,082
Re: Why are crawl space dehumidifiers so expensive?
To your question, a crawlspace is usually cooler thus needs a better dehumidifier to extract the moisture.
But, why is the humidity high?
Your nearest big city will help us understand your weather conditions.
Does the CS have a dirt floor and if so is it covered and sealed with a heavy vapor barrier?
Are there moisture issue down there like rain run off or active sump pit?
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 11-16-2018, 05:26 PM   #3
Rewards Points: 536
Regular units ice up if the temp is too low. As bud asked, why do you want a dehumidifier? How about installing a small window fan and run it 24/7? I do it for my bsmt and it does take out the musty smell, although I know they are different. If not lined, plastic or concrete, maybe this is an idea? Line the ground with french drain pipes (holes), connect them to a fan then cover the whole thing with thick plastic. Just a speculation and never saw anybody do it this way. Just an idea.
carpdad is offline   Reply With Quote
Sealing off a Crawl Space arblargan Insulation 12 09-11-2014 11:41 AM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Odor from Crawl Space G Ollis General DIY Discussions 68 11-02-2013 02:31 AM
Crawl space dehumidifiers? crescere Plumbing 2 05-20-2013 10:24 PM
Vapor barrier issue between crawl space and conditioned basement gregsenne Insulation 3 10-12-2012 12:53 AM
