What's The Typical Size Of The Roof Joist? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-15-2015, 03:27 PM   #1
Rewards Points: 650
What's the typical size of the roof joist?
I need to install a few wall wash recess lights on a vaulted ceiling.
The housing has a 5.5" depth.
Are the joist usually 2x6"
dannieboiz is offline   Reply With Quote
Old 11-15-2015, 03:55 PM   #2
Rewards Points: 4
My vaulted ceiling looks thinner, but the old rafters are 2 x 8's. The reason it looks thinner was the manner of framing at my picture windows at ceiling height is a bit deceiving. If your roof has much length to it 2 x 6's would be small unless they are double thickness, (4 x 6 glued together) which I had at a house I owned many years ago. As you can see, I like vaulted ceilings. Craig
idealassets is offline   Reply With Quote
Old 11-15-2015, 03:58 PM   #3
Rewards Points: 650
The lenght is about 20ft as long as 2x4 isnt in any of the possibilities then i think i can safely assume 5.5" depth is doable
Old 11-15-2015, 04:46 PM   #4
Rewards Points: 7,587
A scissor truss or at least 2x10. The truss mat be 2x4 but should have space above.
A straightened coat hanger with a hand cut chisel point can be used to to test the depth before any large holes are cut.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 11-15-2015, 06:57 PM   #5
Rewards Points: 18,382
They sell low hat recessed IC air tight can lights.
rerplace roof on 200 year old house newroof Roofing/Siding 7 11-24-2013 06:23 PM
Protecting patio roof from water comming from house roof alekas Roofing/Siding 2 07-30-2013 10:40 AM
Flat Roof: Joist Layout, Slope, & Membrane Help Needed! dutchswan0311 Roofing/Siding 10 10-28-2011 01:44 PM
Unfinished garage/ ceiling joist under low pitched roof betto825 Building & Construction 8 12-17-2010 07:16 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
