What To Use On Plywood Floor? Storage Building - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-16-2014, 06:34 PM   #1
Rewards Points: 24
What to use on plywood floor? Storage Building
Just got a storage building for outback that has a plywood floor and I am trying to decide if I want to use some sort of carpet,garage snap tiles,or use a primer and a paint.
The building is 336 sq ft,so using garage tiles would run around $900.
Looks like paint and primer would be around the $150 range and I'm not sure about outdoor carpet. I'm actually leaning towards a good primer and a good paint.
Let me know what you guys used and how you liked it.Thanks
Kev7274 is offline   Reply With Quote
Old 10-16-2014, 06:38 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
carpet will just be a dirt trap.. i would paint it
woodworkbykirk is offline   Reply With Quote
Old 10-16-2014, 06:42 PM   #3
Rewards Points: 24
That was my thinking also.
Old 10-16-2014, 06:50 PM   #4
kwikfishron's Avatar
Rewards Points: 178
If you're going to paint I'd use BM's floor and patio paint, It's epoxy modified. I've used it many times with good results. http://www.benjaminmoore.com/en-us/f...s#advs=0&tab=2
kwikfishron is online now   Reply With Quote
Old 10-16-2014, 07:11 PM   #5
Rewards Points: 2,598
How about some sheet vinyl?
Probably about the same cost, or less cost, as the primer and paint...
ktkelly is offline   Reply With Quote
Old 10-16-2014, 08:20 PM   #6
Rewards Points: 24
Didn't think of that. Ill look into it.
Old 10-16-2014, 08:25 PM   #7
Rewards Points: 24
You use a primer?
Luan Plywood Underlayment BigJim Flooring 12 03-05-2013 05:41 PM
Greenhorn help building aquarium stand. Kribensis Carpentry 40 09-13-2012 03:39 PM
Adding Flooring/Drywall/Insulation in Portable Storage Building Ashley DIY Building & Construction 0 07-12-2012 11:06 PM
Nailing Rigid Foam Boards to Plywood Buscador Roofing/Siding 5 02-05-2012 07:22 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
