What Kind Of Sealer Should I Be Using? Pictures Included. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-18-2014, 07:14 PM   #1
What kind of sealer should I be using? Pictures included.
Bought my first home, wahoo! House was built in 1942 and has a detached garage that is not that old but it isn't sparkling, either.
Problem is, when it rains the garage has a tendency to flood. It takes a pretty good rain, probably only get about 2 of these per summer but the snow is killing it. I am prepared to install french drains which will be pretty easy, I will only need about 20 feet of pipe but I want to start with the path of least resistance and re-caulk the outside of the garage - it needs it regardless.
I cannot find a consistent answer to what kind of caulk should I get, or maybe I shouldn't be using caulk and should be using something else? Pictures down below show how there is a large gap so I assume I will need some sort of filler. It just seems whenever I search I find 50 answers and none of them are the same. Need some help.
What kind of sealer should I be using? Pictures included.-sidewalk1.jpg   What kind of sealer should I be using? Pictures included.-sidewalk2.jpg
mclieberman is offline   Reply With Quote
Old 02-18-2014, 10:46 PM   #2
Rewards Points: 18,118
Just filling that gap is not going to fix it.
The outside wall below grade needed to be waterproofed before back filling.
Gutters, French drain and regrading will be a big help.
Old 02-18-2014, 11:12 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,706
It will be like putting bubble gum in a dam (not damn) leak.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
What kind of cable is this? Sith717 Electrical 3 03-10-2012 02:56 PM
stripping concrete pavers of old failed sealer davearonow General DIY Discussions 10 01-14-2012 01:18 PM
Posting Pictures rjordan392 Site Help and Suggestions 13 08-18-2008 09:25 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
