Thread Tools | Display Modes |
#1 |
Rewards Points: 323
![]() What do you use to repair dents, scratches on baseboard?
My A Hole dog
Sponsored Links | |||
Advertisement |
#2 |
retired painter
Rewards Points: 804
![]() Re: What do you use to repair dents, scratches on baseboard?
When it can't be sanded out and it's not practical to replace - I use Durabond to patch the damage. Regular joint compound will also work and is more diy friendly but it won't be as tough.
Advertisement |
#3 |
Rewards Points: 4,330
Bondo works well, that or Durham's putty would be my first two choices.
Advertisement |
#4 |
retired painter
Rewards Points: 804
Both of those are good choices ..... I usually think Durabond because I usually have a bag of it on hand.
#5 |
Rewards Points: 323
It seems like Durham is a lot cheaper than Bondo at $1.98 for a 1lb can.
#6 |
retired painter
Rewards Points: 804
Durham RockHard Putty is hard to sand so be sure to apply it neatly!
#7 |
Rewards Points: 102
Whatever you use, make sure it's safe for A hole, sounds like he's still hungry.
stick\shift likes this.
The Following User Says Thank You to subbuilder For This Useful Post: |
Sir MixAlot (08-15-2017)
#8 |
Rewards Points: 1,826
If you can't cure dog of his attraction to wood, pick up a length of 2" dowel, cut it up into ten inch pieces and let him chew on that.
#9 |
Rewards Points: 323
My neighbor gave me a leftover,small tub of DAP plastic wood. Not the easiest to work with but hey..it's free. Can i add a lilttle bit of water to soften it a bit , then stir ? It Looks kinda dried.
As for the A hole, he's better behave or imma get a cat ![]() |
#10 |
retired painter
Rewards Points: 804
It's been ages since I used any plastic wood? what does it say on the label? probably doesn't mention thinning but should state something about clean up while still wet.
#11 | |
Master General ReEngineer
Rewards Points: 1,778
![]() Re: What do you use to repair dents, scratches on baseboard?Quote:
![]() Quiet, 'n effective,.... |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
repair scratches in hardwood floor | Cvolpe | Flooring | 14 | 12-30-2017 12:36 PM |
Rotted Baseboard | miamicuse | Carpentry | 11 | 09-08-2013 10:09 AM |
Electric baseboard heat/relay switch issues | Buzzard67 | HVAC | 4 | 10-31-2012 01:32 PM |
Electric Baseboard Convection Heater - Buying House Info? | olimits7 | HVAC | 4 | 10-24-2012 10:45 AM |
Repair or replace baseboard? | handbanana | Painting | 9 | 04-09-2007 07:40 AM |
