Thread Tools | Display Modes |
#16 |
Rewards Points: 358
Keep a little acetone close by when using spray foam. Dampen a rag with it to clean the foam of your hands even after it cures. Works on gorilla glue also.
The Following User Says Thank You to RegeSullivan For This Useful Post: |
cjaustin81 (11-19-2014)
Sponsored Links | |||
Advertisement |
#17 | |
Rewards Points: 1,099
![]() Quote:
Might just use the regular stuff w the gun. |
Advertisement |
#18 |
Rewards Points: 1,468
You may be missing my point. The window and door stuff does not expand as much or with as much force as the regular and cures flexible instead of rock hard like the original. For doing your basement, you can use either and don't need the gun. Problem with the gun is that it is a PITA to clean AND requires a special cleaner. Spend ten bucks total and get a can of window and door and a can of original from Benny's or wherever. Try both and see what works best for you. If you put the great stuff around the perimeter first, you don't have to worry about getting into tiny cracks with the nozzle as it will bind to the foam board. Ron
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Mold problem after unfinished house was closed in for the winter... | lemonbltz | Building & Construction | 28 | 12-30-2011 08:52 PM |
Great Stuff Foam Between Walls | chadwilliam1 | General DIY Discussions | 2 | 07-04-2010 07:37 PM |
Great stuff around boxes? | jamiedolan | Electrical | 6 | 12-15-2008 04:07 PM |
Great Stuff question | amakarevic | Building & Construction | 14 | 01-02-2008 11:28 AM |
foam like Great Stuff that is waterproof | amakarevic | Building & Construction | 1 | 12-30-2007 09:52 PM |
