Village Architect Says "NO" To XPS Use In Basement. - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-28-2013, 10:21 PM   #16
Rewards Points: 996
if the CA is making up his own rules. go talk to the mayor.
Fix'n it is offline   Reply With Quote
Old 10-28-2013, 10:47 PM   #17
Registered User
Rewards Points: 526
If no local additions (BD or Fire Marshall) were made to your code, IL is under the IBC; http://www.reedconstructiondata.com/...odes/illinois/
Under that, fb is allowed under drywall; http://publicecodes.cyberregs.com/ic..._26_sec003.htm
And Federal; http://www.google.com/url?sa=t&rct=j...NBXd7F4za_-LyQ
http://www.google.com/url?sa=t&rct=j...N8bamg&cad=rja
He should know; ""10/13" means R-10 continuous insulated sheathing on the interior or exterior of the home or R-13 cavity insulation at the interior of the basement wall." from your state energy requirements, reboot his software- politely.... from; http://energycode.pnl.gov/EnergyCode...state=Illinois
Gary
Old 10-29-2013, 12:53 AM   #18
Rewards Points: 6,652
Gary, the only way to "reboot" a Northern Illinois lifer inspector, is by accidentally dropping an envelope on their floorboard of their vehicle, or slip it on their clipboard, under the paperwork, when they are not looking.
Old 10-29-2013, 06:56 AM   #19
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,532
Chicago at its finest.
They would be a great place to have a President come from....
The Following 3 Users Say Thank You to Windows on Wash For This Useful Post:
Bondo (11-13-2013), gregzoll (10-29-2013), ToolSeeker (10-29-2013)
Old 10-29-2013, 12:40 PM   #20
You left out a crooked Senator in jail, two governor in a row went to jail, a crooked speaker of the house, along with a mayor up in that area went to jail.
The land of crooked inspectors and politicians, where money speaks.
Old 11-13-2013, 04:23 PM   #21
Originally Posted by ryanmcl View Post
To summarize, i will request/offer this of the village when they open tomorrow:
1. I will add fire blocking to the walls
2. Seal the ceiling and wll joint with fire rated sealant
3. If they still say no i will request them point me to the offical section of code they are using for denial.
Any update??
jpfulton248 is offline   Reply With Quote
Old 11-13-2013, 05:05 PM   #22
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
Sounds like that village has their idiot (inspector).
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-14-2013, 10:48 AM   #23
Rewards Points: 1,602
FYI(not that it helps you now). There is a fire rated foam board that can not only be used, but left uncovered. Superior walls uses it on some of their modular foundations.
mikegp is offline   Reply With Quote
Old 12-03-2013, 03:07 PM   #24
All - Sorry for the long delay but i fianally got around to calling back the ispector. I told him i would be willing to add 1/2" drywall fireblocking at the ceiling and he said that would work. So..... i guess that was easy.
Now- would you say this is the proper way to do drywall fireblocking?
http://www.ifinishedmybasement.com/f...nt/fire-block/
ryanmcl is offline   Reply With Quote
Old 12-03-2013, 11:56 PM   #25
Registered User
Rewards Points: 526
We have our own; #21 and #22: http://www.diychatroom.com/f98/how-f...-37190/index2/
The drywall the guy used in your link will absorb moisture from the concrete wall, either add some poly there (electrical tape the edge) or use better material. http://publicecodes.cyberregs.com/ic...002_par017.htm
http://publicecodes.cyberregs.com/ic...002_par018.htm
http://publicecodes.cyberregs.com/ic...002_par019.htm
Gary
Old 12-04-2013, 09:42 PM   #26
i ran the foam board all the way up to the floor joists, so will fire blocking even serve a purpose at that point? or should i have stopped it at the top of the foundation?
Old 12-05-2013, 03:41 PM   #27
Registered User
Rewards Points: 526
Depends on the local AHJ, some require it between the foams.... the idea is to stop the wall fire from reaching the floor joist cavities, traveling across the basement, going up a plumbing pipe hole, igniting the roof sheathing and house burning down/up at same time. IMO, the fb can burn through (quickly) without a fire-stop.
Gary
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 02:56 AM
Options for new basement Perry401 Building & Construction 8 02-27-2013 10:22 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Definition of a finished basement vs. unfinished hectorlopez Building & Construction 2 01-31-2010 09:31 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
