Venting A Basement Bathroom - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 2 Post By Windows on Wash
  • 1 Post By Bud9051
  • 1 Post By Todd s
  • 1 Post By Todd s
Old 10-08-2019, 12:03 PM   #1
Rewards Points: 8
Venting a basement bathroom
Hi I am planning on putting a bathroom room in my basement. It will have a shower stall, toilet and sink. One issue I am trying to plan for is venting. I have vent less fans and wondered how effective they are. The issue i have is unless I go into the crawlspace i have about a 10 foot run to the closest spot to install a exterior vent. The exterior of the house is brick and i am trying to avoid cutting into that. The place i was thinking about putting the vent is in a glass block window.
my concerns is that is a 10 ft run too far? and is a vent less fan effective and adequate?
thanks
Todd s is offline   Reply With Quote
Old 10-08-2019, 12:09 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,564
Re: Venting a basement bathroom
"Ventless" fans are not effective in my estimation. You have to get the moisture out. Plain and simple. Cutting through brick is not that big an issue if that is the shorter run. It can be done and done cleanly if you take your time and have the right tools.
Nealtw and tdisss like this.
Old 10-08-2019, 12:50 PM   #3
Rewards Points: 8,146
The 10' run is not that bad.
Bud
Nealtw likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 10-08-2019, 03:30 PM   #4
Rewards Points: 8
maybe ill just cut the brick. gotta be a first for everything
Nealtw likes this.
Old 10-08-2019, 03:34 PM   #5
retired framer
Rewards Points: 6,264
That's the right attitude, they make tools for that.
Do not use flat bottom gables with scissor trusses.
Old 10-08-2019, 06:41 PM   #6
You are looking for an SDS hammer drill bit that looks like this:
Should be available at your tool rental. I usually drill the pilot hole all the way though. Slow and steady for a cleaner hole.
lenaitch and Nealtw like this.
Old 10-08-2019, 08:03 PM   #7
Rewards Points: 8
great that helps a lot!
Windows on Wash likes this.
