Vent A Dryer Through A Flat Roof Or Run 21' Out The Wall? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 02:39 PM   #1
Vent a Dryer through a Flat Roof or run 21' out the wall?
Right now my dryer vents into the garage... which is very... very bad.
I am currently remodeling my kitchen and dining room where the washer/dryer is. So now is the perfect time to fix this problem.
I have 2 options...
1. I can run a 4" line with 3 90 degree elbows about 22' around the inside of the garage to an outside wall.
OR
2. I can run straight up with 1 90 degree elbow right out the roof.
However, it is a flat roof... so I dont know how this will work.
What is my best option?
Thanks all!
Integraoligist is offline   Reply With Quote
Old 02-02-2011, 03:48 PM   #2
Rewards Points: 6,652
Keep in mind, that each 90 adds around five feet to the run. I would run the duct through the garage, but insulate it, or box it in and insulate it. You will have to seal the joints with duct mastic since it is running through the garage. If running up through the roof, you need to use the proper vent on the roof, and also have a damper installed inside to close the vent when the dryer is not running. Again, would need to insulate the duct & seal all joints.
Old 02-02-2011, 09:47 PM   #3
Registered User
Rewards Points: 526
I would check the manufacturers duct length on total footage.
I would call your local B.D. on gauge of metal for the garage ducting or hole flashing at the wall. Also any other local requirements they may have.
DIY on a flat roof penetration may be difficult especially if any snow load...
Gary
Old 02-02-2011, 10:43 PM   #4
Today I've got a 16" snow load on the roof... I don't have any local codes as I live in the country middle of no where.
Old 02-03-2011, 09:36 AM   #5
For such a long run to the outside wall you may need a Dryer Vent Booster:
http://residential.fantech.net/resid...-booster-fans/
i_need_help is offline   Reply With Quote
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 05:30 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Vent dryer through flat membrane roof Vince Rosati General DIY Discussions 6 11-02-2008 03:11 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
