Undercoating On Vehicle Trailer? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-08-2014, 04:25 PM   #1
Undercoating on Vehicle trailer?
Anyone ever try using a plasticized roofing tar as an undercoating on a trailer?
PaulBob is offline   Reply With Quote
Old 09-08-2014, 04:37 PM   #2
r0ckstarr's Avatar
Rewards Points: 82
Never used it, have heard of it being used. Are you going to slop it on thick, or thin it and spray it on?
r0ckstarr is offline   Reply With Quote
Old 09-08-2014, 04:55 PM   #3
Well I'm not really sure.. I was thinking about more thickness around the wheel splatter areas.. a bit thinner in others..
I would probably use a brush to apply, then a roller to thin and smooth it out...
Was reading in other places where some had the same ideas and others shot it down.. but no reasons for it.
Old 09-08-2014, 05:12 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 256
PB, I did do that back in 2004 or 5 when I built a teardrop camper, I used the kind that had the fiber in it. To this day it has never leaked or gotten damp at all, it worked for me and still is working.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
PaulBob (09-08-2014), r0ckstarr (09-08-2014)
Old 09-08-2014, 06:33 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,670
Spray on undercoatings are easier to apply but the fiber reinforced once should resist separation a bit better.
Why not just Line-x if the trailer is of some value?
Old 09-08-2014, 08:00 PM   #6
Line-x ?? Is that one of the polyurethane based bed liners? I'll have to check that out..
Old 09-08-2014, 08:59 PM   #7
Old 09-08-2014, 10:39 PM   #8
Ah.. So line-x is one of the polyurethane (polyurea) based coatings.. Its the same stuff as Rhino Liner and about a dozen other brands.
You can buy a very good imitation brush on stuff from the local autoparts stores but the stuff is expensive. A gallon is about a hundred bucks.
Old 09-09-2014, 12:12 PM   #9
Well, I chose to go with the standard spray on undercoating in a can.. Its the cheapest route and should work fine..
I've been working on it all day.. Gotta spray a bit, let it dry.. spray a bit more.. repeat..
Converting Utility Trailer -> Boat Trailer trekkiejt Automotive Repairs 5 07-17-2012 10:53 AM
Do we have any trailer gurus in the house? Mr Chips Automotive Repairs 16 08-11-2011 09:29 PM
trailer light wiring issues utilitylocator Automotive Repairs 5 07-01-2011 01:10 PM
New Trailer service hd82 Electrical 10 04-23-2009 01:26 PM
Trailer brakes bucksone Automotive Repairs 1 09-01-2007 08:47 PM
