Under Floor Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-17-2017, 02:35 PM   #1
Rewards Points: 6
I have a home built on a crawl space and it is sealed. Rats got into the crawl space and destroyed some of the sealing material as well as nested in my insulation. My contractor resealed, removed insulation and added a dehumidifier. Do I need to put the under floor insulation back?
lazybear is offline   Reply With Quote
Old 08-17-2017, 02:39 PM   #2
Rewards Points: 4,330
Re: Under Floor Insulation
Crawlspaces are generally sealed from the outside air and open to the house air or vice-versa. If open to the house air, the walls are insulated. If open to the outside air, the ceiling get insulated.
stick\shift is offline   Reply With Quote
Old 08-17-2017, 05:25 PM   #3
Rewards Points: 7,110
Hi bear, where are you, warm or cold climate?
I assume that insulation that was removed was in the floor. Do you have heat ducts exposed down there, water pipes, or any appliances? Is the floor concrete or dirt?
Bud
Bud9051 is online now   Reply With Quote
Old 08-17-2017, 09:18 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,730
Sounds like were mixing terminology is a bit here. Answer @Bud9051 questions and will be able to point you in the right direction.
