Trouble With Mortise Entry Lock - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2016, 10:37 AM   #1
Rewards Points: 145
Trouble with mortise entry lock
My front door has a mortise lock set. The main latch works fine, however the built in deadbolt (top lock) is having trouble. I've tightened the 2 bolts as tight as I can, however the key lock won't stay tight, it will rotate with the key when turning. Something I'm doing wrong?
kjmass1 is offline   Reply With Quote
Old 04-29-2016, 12:31 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,468
Re: Trouble with mortise entry lock
Could be stripped interior.
Best bet it to just pull the thing out and give it a tune up of sorts.
Once you pull it out, how they work makes perfect sense.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (04-29-2016)
Old 04-29-2016, 12:52 PM   #3
Retired Moderator
Rewards Points: 7,174
If you don't want to fix that yourself---most lock shops will rebuild those old units and send it back as good as new.
Old 04-29-2016, 01:27 PM   #4
Rewards Points: 145
Great thanks. I've taken apart smaller interior door ones but this one is a different beast. It must be stripped or somehow not catching the lock cylinder. I'll grab a couple more pics when o get home.
The Following User Says Thank You to kjmass1 For This Useful Post:
Old 05-01-2016, 02:48 AM   #5
Rewards Points: 145
So I removed the trim piece and discovered that if the cylinder was turned 7 times the lock worked fine. With the trim piece on I could only get 6 turns so I forced it a pipe wrench and now it works! Thanks.
oh'mike (05-01-2016)
Any reason to lock out heat pump swilk HVAC 9 02-03-2014 06:34 PM
Kwikset 'smart key' door locks good? darsunt General DIY Discussions 32 03-10-2013 11:31 AM
Front door lock gets stuck injvstice Windows and Doors 13 03-22-2012 12:31 PM
Special Door Lock for gates? acerunner General DIY Discussions 4 09-27-2011 09:42 PM
Lock part for Vintage Schlage privacy lock? JustMe00 Carpentry 2 09-14-2011 07:14 AM
