DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   General DIY Discussions (https://www.diychatroom.com/f2/)
-   -   Trouble with mortise entry lock (https://www.diychatroom.com/f2/trouble-mortise-entry-lock-392225/)
kjmass1 04-29-2016 10:37 AM
My front door has a mortise lock set. The main latch works fine, however the built in deadbolt (top lock) is having trouble. I've tightened the 2 bolts as tight as I can, however the key lock won't stay tight, it will rotate with the key when turning. Something I'm doing wrong?
http://uploads.tapatalk-cdn.com/2016...73bbbbf23a.jpghttp://uploads.tapatalk-cdn.com/2016...4f2732d899.jpg
Windows on Wash 04-29-2016 12:31 PM
Re: Trouble with mortise entry lock
Could be stripped interior.
Best bet it to just pull the thing out and give it a tune up of sorts.
Once you pull it out, how they work makes perfect sense.
oh'mike 04-29-2016 12:52 PM
If you don't want to fix that yourself---most lock shops will rebuild those old units and send it back as good as new.
kjmass1 04-29-2016 01:27 PM
Great thanks. I've taken apart smaller interior door ones but this one is a different beast. It must be stripped or somehow not catching the lock cylinder. I'll grab a couple more pics when o get home.
kjmass1 05-01-2016 02:48 AM
So I removed the trim piece and discovered that if the cylinder was turned 7 times the lock worked fine. With the trim piece on I could only get 6 turns so I forced it a pipe wrench and now it works! Thanks.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
