Transformer Not The Same - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Chris616
Old 01-14-2020, 11:03 AM   #1
Rewards Points: 68
Transformer not the same
Can I use a 240 / 24V 40VA transformer in place of a 120 / 24V 40VA transformer?
Alex Collins is offline   Reply With Quote
Old 01-15-2020, 11:20 AM   #2
Rewards Points: 158
Re: Transformer not the same
If your question is:
Is the output from a 240/24V 40 VA transformer supplied with 240V power the same as the output from a 120/24V 40 VA transformer supplied with 120V power?, then the answer is yes.
Is the output from a 240/24V 40 VA transformer supplied with 120V power the same as the output from a 120/24V 40 VA transformer supplied with 120V power?, then the answer is no.
In a simple single phase voltage transformer, the ratio of output voltage to input voltage remains constant, so in the second scenario above the output voltage would drop in half to 12V.
Chris
Msradell likes this.
Chris616 is offline   Reply With Quote
The Following User Says Thank You to Chris616 For This Useful Post:
Alex Collins (01-15-2020)
Old 01-17-2020, 09:43 AM   #3
Rewards Points: 6
hello guys t from a 240/24V 40 VA transformer supplied with 120V power the same as the output from a 120/24V 40 VA transformer supplied with 120V power?”, then the answer is no.
Auditore1 is offline   Reply With Quote
Old 01-17-2020, 10:57 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,136
The only way you can use it is if you connect it to 240 volts instead of 120 volts.
