Trailer Tires - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Nealtw
  • 1 Post By Yodaman
  • 1 Post By That Guy
Old 06-14-2019, 07:21 PM   #1
Rewards Points: 3,552
Trailer tires
I have a small 7x14 trailer with 1 axle. and need new tires for it.
Why cant I put LT or car tires on it?
Yet my 1700lb diesel air compressor, has car tires on it??
Originally Posted by Bud9051
Of course they had already been around for over 200 million years but on a planet that could go for billions of years maybe captain Kirk would have had big teeth and a long tail.
That Guy is offline   Reply With Quote
Old 06-14-2019, 07:27 PM   #2
retired framer
Rewards Points: 4,616
Re: Trailer tires
Trailer tires have stiffer sidewalls to combat sway.
BigJim and lenaitch like this.
Do not use flat bottom gables with scissor trusses.
Old 06-14-2019, 07:36 PM   #3
Property Mgt/Maint
Rewards Points: 7,394
Re: Trailer tires
What I have encountered is by the time the tire is shot, the rim is also. I don't have the patience to sand and repaint them, so I buy a new tire and rim together. You can pick them up at Tractor supply for a reasonable price.
chandler48 likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 06-14-2019, 07:40 PM   #4
Re: Trailer tires
my rims arnt rusty at all. They still look new... just the tires are bald lol
Yodaman likes this.
Old 06-14-2019, 10:06 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 706
Re: Trailer tires
You can put passenger car or light truck tires on a trailer - it's done all the time - but as Neal points out, trailer tires have stiffer side walls. Having bald tires is not typical. Most people look at their trailer tires and see good tread but the rubber has been cooked by the sun.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 06-15-2019, 06:06 AM   #6
Naildriver
chandler48's Avatar
Rewards Points: 826
Re: Trailer tires
One of my trailers utilizes a mobile home axle and wheels. I don't like mobile home tires since they are manufactured for a one time shot and not for repeated highway use. However, my tire guy suggested that I install "highway" rated tires on the rims, which I did and can tell the wear difference as well as a smoother ride.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-15-2019, 06:43 AM   #7
retired painter
Rewards Points: 1,416
Re: Trailer tires
If I understand correctly, MH tires aren't legal for regular trailer use BUT I have a tandem axle trailer that's big enough to transport most cars or my tractor and it's never had anything but MH tires on it since I bought it used in 1991. Not sure what would happen if I ever got stopped but as the yrs go by I use it less. It probably only went down the road a dozen times in the last year - half of which was when my grandson borrowed it.
mark sr is offline   Reply With Quote
Old 06-15-2019, 09:12 AM   #8
Rewards Points: 7,473
Re: Trailer tires
Check Wal-Mart. Here they have the best price and one mounted on a new rim is only about $5.00 more than just the tire.
Do take note of which load rating A, B or C you have now and buy the same tire or better for the same load rating.
For curiosity I just looked at Amazon and they beat WM https://www.amazon.com/Trailer-Tires...%2C165&sr=8-10
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
