Texture Backer Board? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-18-2018, 03:37 AM   #1
Texture backer board?
Hi, I've been dealing with a problem lately that's been bugging me. I have a window ac and since the heatwave I've been running it a lot. The drywall around the windows is starting to fall apart. I have always made sure that there were no leaks and that the wall was always dry. But twice now I've had to cut away the bad drywall and replace it(using water resistant drywall). I'm at the point of just using backer board around the area. But my question is if I do that can I texture the backer board to match the drywall? I only plan on using one sheet.
Vkfenrir is offline   Reply With Quote
Old 08-18-2018, 05:52 AM   #2
retired painter
Rewards Points: 1,754
Re: Texture backer board?
Cement board should texture ok although you'd need to skim coat it first. Cement board only comes in 3'x5' sheets.
mark sr is online now   Reply With Quote
Old 08-18-2018, 11:12 AM   #3
Rewards Points: 4
Drywall mud an tape will both stick to backer board.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline   Reply With Quote
Some uneven spots on backer board scotte1975 Tiling, ceramics, marble 5 02-24-2012 02:55 PM
re-using concrete backer board caldew Kitchen & Bath Remodeling 2 02-24-2012 07:36 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 10:18 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 02:30 PM
